Go Back   EcoModder Forum > cfg83's Profile > Albums
Air Dam
Air Dam in horizontal (non-deployed) position over low curb.
Spring mounted air dam.  Air dam is made of two parts, each slightly angled "cowcatcher" style to push the air to the sides.  Each side of the air...
Air dam is in two parts.  Each side is attached using a piano hinge to block any air and allow for a stable relationship of the dam to the oncoming...
Detail of spring and chain.  Zip ties connect them and act as failure points if the air dam hits something on the freeway.
Side View deployed.  The part that isn't attached to the piano hinge will be bent by the wind.
