Old 04-21-2012, 04:26 PM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
328i Shooting Brake LPG- The Mods thread!
Recently acquired this 1997 BMW 328i Touring (estate) fitted with an LPG system..
its got 193 BHP, and is geared for 2500rpm at 60mph with a 5 speed Manual
weight is circa 1500kg, and the Cd is similar to my 318iS (0.30)
its being used to do the 48 mile round trip to my work daily, coupled with runs to/from my unit at the weekends
Fuel logging is currently working this way..
Petrol tank filled
LPG filled to 45L (from empty)
Run until LPG is out and refill to 45L
Car will start on LPG, so the petrol is really only there incase I run out without having LPG to hand..
Have an LPG station 1 mile from house, and 1 mile from work, so have made it to stations easily.
I'll top up the petrol once 1/2 the tank is used, so I know total number of gallons (LPG and petrol) used to cover the miles. this will give a combined fuel MPG
any suggestions re this recording method?
anyways Here's some pics:
Car needs front tyres changed to correct 205/55/16s- will do asap
As per usual- open to any suggestions/hints/tips you have re aero/modding or driving technique
Cheers!
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
The Following User Says Thank You to 320touring For This Useful Post:
BamZipPow (05-19-2012)
Old 04-23-2012, 07:24 AM   #2 (permalink)
Team m8
A fairly successful weekend.
Got 2x part worn 205/55/16 off a mate for free (always the best price!) just need to get them fitted
First Mod already done..
Removed the 1! rear mudflap..
Also gor some pics of the front grilles and engine bay so I can have a look and see options.
I'm thinking the WAI may be difficult to do- and I dont know if the MAF meter will respond to it?
Old 05-16-2012, 08:53 AM   #3 (permalink)
Team m8
Hoping to get some actual modding done on this at the weekend- got distracted with new bits for the old 320touring!
may try to measure up for front grillblocks and some under-panels.
Potential also to try and lose some weight from the car inconspicuously- should help during the pulse part of P&G
Old 05-16-2012, 12:22 PM   #4 (permalink)
Doug - '03 Chrysler PT Cruiser Base
90 day: 31.16 mpg (US)
DR 350 - '92 Suzuki DR 350 S
90 day: 61.09 mpg (US)
Sid the Sloth - '82 Honda Civic CVCC Wagon
Last 3: 35.93 mpg (US)
Rocky - '92 Daihatsu Rocky
Last 3: 24.97 mpg (US)
Mick - '97 Jeep Cherokee XJ UpCountry
90 day: 19.4 mpg (US)
A four door wagon isn't considered a "shooting brake". Never-the-less I am very jealous of that ride. I wish wagon BMWs were more available here in the states.
Old 05-16-2012, 01:27 PM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Ditch the roofrails if you don't use them.
Old 05-16-2012, 01:38 PM   #6 (permalink)
It could be worth removing the roof rails if you don't use them and replacing the crank-driven fan with an electric one.
Old 05-16-2012, 03:44 PM   #7 (permalink)
Team m8
its a hatchback! estate...
so it is
Old 05-16-2012, 03:47 PM   #8 (permalink)
Team m8
thhe roof rails appear to be bolted in from underneath- possibly requiring the removal of thee roof trim inside.
I think there are better or similar gains to be hadd elsewhere with less work?
I'll bear them in mind though.
crank driven fan replaced with electric one is on the list- just need to find one that costs less than a full tank of LPG to make it worthwhile..
cheers for the suggestions fellas
Old 05-17-2012, 04:47 PM   #9 (permalink)
Team m8
new best LPG tank in..
38.01L for 257.6 miles- 30.82 imp mpg!
If ever there was an incentive to do better!
Old 05-19-2012, 11:58 AM   #10 (permalink)
Focussing on drag reduction might be best for your commute, especially if its at motorway speeds. the grille blocks and undertray mentioned are good mods. the best mod might be a kammback somewhat like piwoslaws:
http://ecomodder.com/forum/showthrea...read-9040.html
Later Citroen Saxos have a fairly slim electric fan which uses a seperate loom with all the relays etc. Should be cheaper than a tank of lpg on ebay or a scrapyard too
