Old 05-22-2008, 10:05 AM   #11 (permalink)
Pushrod - '02 Chevrolet Cavalier
That's not my experience using one in controlled conditions. The last series of back-to-back runs I did testing vortex generators had a standard deviation of .6%. I'd call that decent resolution. It's less important that the absolute MPG readings are 100% accurate, as long as the relative differences are consistent.
Don't confuse resolution with accuracy. SG only correctly accounts for stoich, no other mixture. Even then, it's flawed. Just because it ends up being pretty close when you fill up doesn't mean that trip averages in certain conditions are accurate. While it can be accurate for external factors like aero drag, it cannot give results for things that affect the quality of combustion, like lean burn and acetone. Because it is an air meter, it can't tell you that you traveled the same distance using less fuel. If you used the same amount of air during that trip, it will report no difference.
Old 05-22-2008, 10:57 AM   #12 (permalink)
is awesome
The fact that you already believe it works will be detrimental to your cause. You need somebody who doesn't really care, either way.
KU School of Engineering
'72 Datsun 240z
'96 Chevy lumina
Old 05-22-2008, 11:16 AM   #13 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
i dont care either way... but why do you keep claimning that ethanol is damaging??
Old 05-22-2008, 12:03 PM   #14 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
mechanically ethonal is not damaging, it simply reduces FE. Not the most FE solution to our dependence on oil.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-22-2008, 12:18 PM   #15 (permalink)
90 day: 51.82 mpg (US)
That's true. I missed your point in relation to this thread.
Old 05-22-2008, 12:56 PM   #16 (permalink)
ok, thats what i thought, i have used ethanol for years with no bad side effects, and switching from 10%-20% eth in my jeep (jeep 2) did not harm mpg but ehh thats a whole discussion on its own so i will leave that alone...
Old 05-22-2008, 01:09 PM   #17 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
Using ethanol brings me down from almost 24 down to 19-21. And if you figure it out, that loss isn't worth the 10 cents a gallon less. Ethanol needs to be cheaper/BTU's before it replaces any part in gasoline (even mixing).
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 05-22-2008, 01:27 PM   #18 (permalink)
If engines were specifically designed to run on E10 gasoline (higher compression) you wouldn't see much of a loss in mileage. This is probably the way things will go eventually. However, right now manufacturers need to make an engine that can run on both forms of fuel and that is a compromise that costs us mileage.
The Following User Says Thank You to Daox For This Useful Post:
undeRGRound (11-11-2014)
Old 05-22-2008, 02:14 PM   #19 (permalink)
DPoV what mixture of ethanol are you using?? i had a chrysler T&C (flex fuel) and i ran e85 on it and didnt see that much of a loss (maybe 2mpg), as is any modern vehicle should not see much of a difference on e10.. but if your vehicle is not calibrated for e85 and you try to use it you will have a huge difference because your computer will read the exhaust as being lean and will dump more fuel in to compensate for the perceived lean state.
Old 05-22-2008, 02:48 PM   #20 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
What if you divide the MAF value by lambda (assuming you have an accurate lambda value)?
www.HyperKilometreur.com - Quand chaque goutte compte...
MetroMPG.com mailbag: why don't you test acetone? MetroMPG General Efficiency Discussion 21 11-18-2014 05:00 PM
Adding Acetone as an additive to gasoline - worthwhile? havok95z71 General Efficiency Discussion 14 01-18-2009 11:29 PM
Covering entire bottom of truck with plastic boostanddestroy Aerodynamics 9 05-20-2008 05:05 PM
the bottom line, people have be forced to conserve. diesel_john General Efficiency Discussion 57 05-17-2008 11:37 PM
Video: The Crazy Thing About Acetone. Peakster EcoModding Central 10 01-15-2008 02:47 AM
