03-03-2010, 05:13 PM
Pokémoderator
LED Headlight for trucks ...
Hello -
If you have a round headlight, this may be your bag :
03/23/2009 - World's First 7" Round LED Headlamp Shows Bright Possibilities for Commercial Applications
March, 2009, Falconer, New York - The 12 volt extended product line release of the world’s first 7” round LED Headlamp has enabled Truck-Lite to come full circle as your premier See & Be Seen® LED lighting supplier, lighting your way from the front of the truck to the rear of the trailer. This new and exciting LED Headlamp innovation provides a new level of performance for 7” round forward lighting 12 volt applications, offering the extended life and energy efficiency of light emitting diode technology.
Truck-Lite - Catalog Product : 7'' Round 12v LED Headlamp
- DOT Approved, High Beam and Low Beam performance
- Provides light output closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
- Solid-state design resists damage from shock & vibration
- Offers as much as 50x longer life (10,000 hrs vs 400 hrs) than comparable incandescent lamps, saving the time and expense of replacing lamps multiple times
- Hard wired design, fully encapsulated electronics & anodized aluminum housing protect from damage caused by corrosive elements
- Impact resistant polycarbonate lens protected against damage caused by debris and other hazards
- Direct replacement for Par 56, H6014 and H6024 lamps
- 3-Year Limited Warranty
- 24v Version available, Part No. 07370
Light Source:
10 Light Emitting Diodes (LEDs)
Designed at 12.8v
4.5a (High Beam), 2.5a (Low Beam)
CarloSW2
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
03-03-2010, 08:00 PM
I hope they also make smaller sized units, like projector beams, etc. That would be sweet for my CarBEN design!
03-03-2010, 08:15 PM
Pokémoderator
Neil -
They're 7" in diameter, so that sounds "Beetle Size" to me.
CarloSW2
03-03-2010, 09:54 PM
They seem like they are the size of the old sealed beam headlights? The ones that were one on each side.
03-04-2010, 12:38 AM
Correct. 7" round is an old sealed beam size. They are plug and play into a lot of older cars. The military has started using these in just about everything.
The quality of the beam pattern on the other hand...
Sealed beam.
Low beam
high beam
$600/pair
03-04-2010, 02:10 AM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Price is semi-ridiculous. I won't spend $600 on headlight replacements in the life of maybe 10 vehicles, and those headlamps won't last that long.
Even with HID's, I wouldn't spend that much on several vehicles' replacements.
Maybe it's a step in the positive, though. Someone will probably tear into 'em and find out what makes 'em tick, then post the results online, just like game system modders.
Anyway - they're 10 LED units, so maybe what Wagonman76 is working on will actually work!
03-04-2010, 02:31 AM
Why do they draw so much juice? 250mA per LED in low beam sounds like a lot of electricity, doesn't even cut a standard halide bulb amp draw in half. Hella & VW are working on some that are only 19W per beam, about 1.5A. See
ht tp://tinyurl.com/yk438yp
about halfway down. I think I will wait a little until high production brings down the price, too.
03-04-2010, 02:36 AM
19W/12V=1.6A
250mA*5LED's = 1.25A...
I'm not sure where Hella's lights are any better?
03-04-2010, 02:55 AM
#9 (permalink)
Well a pair of drop in 35w HIDs is $40.
03-04-2010, 12:47 PM
#10 (permalink)
That VX guy!
(posted from the HIDplanet forum)
The trucklite round? looks like a wide, dim rectangle with a bright square in the middle.
Here it is in comparison to stock headlamps on a jeep, IIRC, pic by GhostDakota:
Not a great beam pattern in my eyes considering the ls600hl LED triple projectors do better for light output consistency:
Those 7" LED headlights would be blinding to any driver caught in oncoming traffic.
And plu-n-play (drop-in) HID kits into a stock reflector housing are a huge no-no, they're even illegal to have in a lot of states.
