Old 12-22-2008, 08:14 AM   #11 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
it's not something we are likely to find in England
i wouldn't be too sure about that, over here in belgium it's often used to make window inserts so you can have the bedroom window open in summer without letting mousquitos in
its mostely a grey plastic like material and in some places they'll cut it to the size you want... i've used this in some grill block experiments, although i don't have it on my car now
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 12-22-2008, 01:38 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
yeah, it's usually used in storm windows. It would also be found in a porch door (screen door), for instance.
Old 12-22-2008, 02:03 PM   #13 (permalink)
08 xB - '08 Scion xB
90 day: 35.5 mpg (US)
Here is a place that sells stainless steel mesh. Pegasus -Stainless Steel Wire Mesh
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 12:30 AM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
