11-13-2014, 11:27 PM
#41 (permalink)
Red Light Avoider
That's awesome.
11-14-2014, 03:41 AM
#42 (permalink)
Focus - '05 Ford Focus tdci Futura
That looks neat. Just a good valve on it to adust is and your good.
Just a idea. How about a valve in one of the 2 pipes. In stead of a Y valve. You can test wich you need to put it in. And its easier and cheaper
11-14-2014, 03:57 PM
#43 (permalink)
In my application I need full hot to reach 100f in winter, and full cold to keep intake temps below 150f in summer. So for my car I must have the option to close off one side AND the other.
The Following User Says Thank You to ecoTex For This Useful Post:
11-15-2014, 03:24 PM
#44 (permalink)
Manual operation is fine for testing.
Its time to get some automation going.
The easiest simplest way I can think of to automate this process is to stay mechanical use a heater core to warm the air with coolant and put an adjustable thermostatic valve with sensing bulb.
Set it and forget it.
Maybe add a N/O valve to close off the coolant flow to the heater core for up hill, passing, trailer pulling, where you generally want cooler air so you don't get detonation.
11-15-2014, 03:29 PM
#45 (permalink)
I'd like to see that!
11-15-2014, 03:42 PM
#46 (permalink)
I don't have an application for it. But I would advise on how to build one.
11-15-2014, 03:57 PM
#47 (permalink)
I wouldn't want to use coolant heat in the winter, at least not in the Vx. It already has trouble staying at temp. Summer would probably work though
11-29-2014, 04:39 PM
#48 (permalink)
halos.com
Originally Posted by ecoTex
ECONORAM, have you seen this pic from the Donkey CRX's build thread? It is on the "show car" white vx that belongs to my uncle. I believe it is in the top five right now. This is a prototype HAI. Pretty slick!
Yep. Some nice work there. I have thought about that too. Might have to try it if I follow that pattern. The first time I used some 4" dryer hose that I split open to cover the exhaust manifold and I didn't get much temp rise. That may be 'cuz I have some exhaust wrap keeping most of the heat in the manifolds...
11-30-2014, 12:57 AM
#49 (permalink)
Not if you did this:
http://ecomodder.com/forum/showthrea...ler-29085.html
Faster warm ups, likely unlimited heat for your cabin heater and intake air warmer.
