Old 04-06-2008, 09:47 PM   #1 (permalink)
Why not use this for undertray wheel deflectors & fairings?
http://www.drillspot.com/pimages/269/26977_300.jpg
Cut off the corners diagonally, making inverted ramps, to attach to the underbody of the car in front of each wheel. The same application behind each wheel would act as a fairing.
Each of these $5.37 polyethylene trash cans would make two deflectors.
Tough and resilient, these would resume their shape after hitting a curb.
Old 04-06-2008, 09:49 PM   #2 (permalink)
You can get a roll of 14"x25'x.19" thick aluminum roll for $15 at Home Depot.
Old 04-06-2008, 10:01 PM   #3 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Do it
I've had to stay out of the plastic tub isles for the past few months... I always try and re-purpose the shapes The last thing I did was use a trash can for a knight helmet and some other random thing for vambraces (for the same costume)
If you're by a university - I suggest some dumpster dipping around move out time.... You'll find plenty of those
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-07-2008, 12:08 AM   #4 (permalink)
Is this stuff stiff enough to be used without backing? Can it be readily used for undertrays, or must you add stiffeners?
Alu. has excellent heat dispersal characteristics, so is very good around heat sources such as exhaust pipes. Could make noise, though.
How about a sandwich panel using this alu. and Coroplast? Do the undertrays with Coroplast, and add alu. sheet where needed as a heat reflector/barrier.
What sort of adhesive could be used for a Coroplast/alu. sandwich panel? Silicone bathtub caulk?
Old 04-07-2008, 12:12 AM   #5 (permalink)
Originally Posted by trebuchet03 View Post
Do it
How easily can the molded shape of these PE things be modified with a heat gun?
I've also been looking sideways at wife's Tupperware. They make some potentially useful oval stuff that, cut in half, would make great streamlined wheel fairings. Google for "oval Tupperware."
Old 04-07-2008, 12:18 AM   #6 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Ok, the 0.019" will actually develop cyclic fatigue cracks on the front, so far it is holding up on the back.
I would like to know how to laminate it also.
OTTO, i am trying to visualize which way you want to divert the air around the wheels, and how you are going to keep the air where you want it.
Old 04-07-2008, 01:48 AM   #7 (permalink)
Originally Posted by diesel_john View Post
do you mean 0.019" thick. 0.19 for 15 bucks would be a heck of a deal, but it won't be in a roll, because that thicker than a road sign.
Yes, my bad.
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 41 10-14-2019 10:22 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
wheel skirts for 91 civic bbb3108 Aerodynamics 11 03-11-2008 12:39 AM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
