Aero hubcaps or rims?
I've been researching hubcaps and rims. Moon discs? pizza pans? but I want to go with a lighter wheel(steel wheels as of now) but thinking hubcaps till I get new wheels and tires. I have a 99 Camry with these hubcaps
http://hubcapsonwheels.com/images/61...mry_hubcap.jpg http://hubcapsonwheels.com/images/61...mry_hubcap.jpg I've been looking at moon discs but they aren't completely flat right? I found these that may be a little better and slightly cheaper http://grumps-garage.com/images/bhc01.jpg 73 with shipping Ideas? Suggestions? |
1 Attachment(s)
I have 3 ideas Most to least expensive 1) buy new rims that are more aero and lighter 2) buy moon discs and yes they are not flat 3) make flat circles out of coroplast for smooth wheel covers, and beings you have steelies they fit inside of the lip around the outer edge of the wheel and can be easily install with zipties |
4) cut a disc out of some material (coro, or whatever) and affix it to the existing hubcap.
PS: your OEM hubcaps look pretty good (they're not air blenders). I don't think you'll get a big enough savings from buying aftermarket discs to make up the cost in a reasonable amout of time (if that's your goal). |
Thanks yeah I may try and make something cheap
