Old 10-17-2008, 11:54 AM   #1 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
Body Kits
Has anyone checked out body kits for their car? The cheapest I could find is $625. I want to put on an air dam and side skirts, but not for $625. I think I'm going to try to find something that looks close to OEM, but isn't $625. I've considered coroplast, but I want it to look like it's supposed to be there, it's hard to convince other people to mod their vehicle if yours looks bad. Any ideas?
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 10-17-2008, 12:41 PM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
problem with bodykits is that desides a heavy pricetag, is that they're mostely designed to look good and perhaps help aero, but it's quite a gamble... after laying out all that money it would hurt to see your fe go down.
if you're a little bit handy and you want good looking functional mods, invest in some quality materials. some things like plastic gutters of sheet plastic can be obtained
if your shooting for functional mods it doesn't matter that they're very eye catching so if your worried about looks, a lot of things like airdams and sideskirts can be build in a discrete finish so that you won't notice them at a casual glance,
if you paint them in a flat of satin black that matches the plastic on the car things will look pretty stock. a lot of people here see their mods as an ongoing experiment, but things that have proven to work are sometimes rebuild in stunning quality, wich from the picture i've seen look almost factory installed.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 10-17-2008, 07:05 PM   #3 (permalink)
econ00b
green car - '91 honda civic hb dx
Fiberglass is actually very easy to work with, if you wanted to attempt building your own. The site Ive learned the most from would be www.fiberglassforums.com
Using foam, you can create the shapes you want, then glass over them. This thread in particular is almost like a guide to making your own body kit. highvoltage77's build thread
Old 10-18-2008, 11:27 AM   #4 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Chevy Metro LSi
90 day: 48.88 mpg (US)
was there ever a Body kit made for the Metro???? anyone mod another kit to fit? i'm just curious.
Old 10-20-2008, 01:09 AM   #5 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
saunders1313,
if you want cheap and OEM - go fankendam
get/find a junk air dam/skirt you like & fits your needs and hack it into your vehicle
get the OEM look (compound contours and shapes) but not the price
I happened upon a busted air dam for free (friendly neighbor - I think it is from an expedition)
trimmed it down to fit my truck - and now I have a OEMish air dam
I don't clam it is pretty - but that is my fault
with a little work it could be down right nice
take a walk thru the salvage yard with a tape measure
- you might be surprised at what you find
sorry, no before shots
here is a stock s10 photo
note dam is now about 4" lower than stock & nicely rounded
- just low enough to block & smooth the air past the A-arms etc. perfect
Of course
trikkonceptz is the master of this sort of thing - his work does look nice
link - if you have not seen it
http://ecomodder.com/forum/showthrea...-0-a-2202.html
Concrete
Start where you are - Use what you have - Do what you can.
Old 02-28-2009, 11:41 PM   #6 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Past Present Future?
Old 03-01-2009, 10:41 PM   #7 (permalink)
Young'n
Red Dread - '03 Ford Ranger FX4 Level II
90 day: 19.81 mpg (US)
Bessie - '08 Honda Civic Hybrid
Lmao, on a metro. BEA-utiful
Body integrated radiator method, requires no grill or openings... blackjackel Aerodynamics 50 08-18-2013 06:06 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Big Bore throttle body for MPG? cfg83 EcoModding Central 19 12-31-2008 09:44 PM
Foam Body Mods taken to a whole new level... mattW Aerodynamics 2 09-21-2008 12:20 AM
