Old 08-22-2010, 07:52 PM   #1 (permalink)
Got soul?
Soulster's Avatar
Soulster - '10 Kia Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Dodge Neon
Aero question...
Should I take the spoiler off?
Old 08-23-2010, 02:37 AM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Looking at pics of other Souls, it's not a standard feature, so it most probably doesn't help much.
Those without a seperate spoiler like yours seem to have a small integrated spoiler though. Is that also on your Soul ?
Hint : delete the mud flaps
Old 08-23-2010, 06:58 PM   #3 (permalink)
Got soul?
Soulster's Avatar
Not sure about the separate spoiler part..
Would deleting the mud flaps help that much?
Old 08-23-2010, 11:39 PM   #4 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
The mud flaps are there for a reason, they will reduce your "wake" in rainy weather and wet roads. You would be better off boat tailing them... I removed mine (because they were old and brittle) and saw no improvement, I have been thinking about boat tailing the wheels, but haven't gotten around to it yet.
Removing the spoiler should help, replacing it with a Kamm-type-back would help, check out what Weather Spotter has been doing with his vehicle... you both have similar hatch setups, you may be able to leverage off his experience.
Old 08-24-2010, 03:25 AM   #5 (permalink)
euromodder's Avatar
Most mods won't help much - you've already done one of the most effective : the front grill block.
Anything may only help a little bit on its own, but all those little bits added together start making a serious difference.
If you look at my fuel log, it's all down to changes in the way I drive, less AC use, some weight reduction, and now the grill block.
I used to be happy with the rather decent 43mpg I got on the first entry - but the last entry so far is over 52mpg
kia, soul
Aero cap question hat_man EcoModding Central 0 07-24-2010 02:38 PM
Aero question jcp123 EcoModding Central 3 12-28-2009 06:45 PM
Wiper aero question (vertically parked) Christ Aerodynamics 11 04-15-2009 08:47 PM
EV-1 aero question Otto Aerodynamics 3 04-09-2008 05:03 PM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
