Old 01-17-2020, 11:01 AM   #1 (permalink)
Aero roof bike rack.
I was thinking of building a roof rack for my mountain bike. I would like to accomplish two things.
Be as aerodynamically clean as possible and protect my bike.
I would like something similar to the aero roof storage shells you can buy. If I pull the seat, pedals and front wheel, I can can get everything into a space roughly 10"x33". I would taper it at the lead edge where the turned sideways handlebars would be and I only need a few inches of height.
Has anyone done anything like this? It would fit nicely between the roof rails of my Jetta Sportwagen.
Has anyone built anything similar?
Is there such a thing I can buy off the shelf that isn't ridiculously heavy?
Old 01-17-2020, 11:53 AM   #2 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I assume 10 wide and 33 high, how long?
How long does it take to pull the pedals? I know the seat and wheel should be quick, but tiresome to do on a regular basis.
Is there a reason you would not want a box/carrier that goes on the back in a receiver hitch? You could shape it like a tapered body extension and make your MPG improve.
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
pete c (01-17-2020), Xist (01-18-2020)
Old 01-17-2020, 12:36 PM   #3 (permalink)
Pedals are off in seconds with a 17?mm wrench. I would likely just pull the left pedal anyway. This keeps the bottom bracket and pedal from being stressed.
I've had that same thought about a hitch receiver boattail..
The only issue with that is that it limits hatch access.
A roof container would be simpler, lighter and useful as storage for other things.
Old 01-17-2020, 01:44 PM   #4 (permalink)
90 day: 29.78 mpg (US)
They make receiver bike racks that tilt out of the way of the hatch.
Xist (01-18-2020)
Old 01-17-2020, 07:50 PM   #5 (permalink)
The best arrow roof rack is the one that's easily removable and installable.
Xist (01-18-2020)
Old 01-17-2020, 10:04 PM   #6 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I've thought about this a lot, driving to races and traveling and whatnot.
First choice: put the bike inside the car. Is there a reason you aren't predicting having enough space inside to do that?
Second choice: A framework or suspended net to carry the bike at the ceiling, inside the car. Keeps the floor space free, slide the bike in from the back and go.
Neither of those will impact the aerodynamic profile of the car. If you need to carry the bike outside, you can expect to have a box similar in dimensions to a travel box--and those are quite large. I flew with one of my bikes once, years ago, so I bought a Performance Bike box; it was plastic but still quite heavy, and around 1' x 3' x 4'.
Found it: it was an Xport cargo box.
(Not my photos).
That's about as small as you'll be able to go without buying a folding bike; both wheels had to come off to fit in that box. May be a good starting point to think about designs. With what material are you hoping to build the box?
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Xist (01-18-2020)
Old 01-18-2020, 03:23 PM   #7 (permalink)
rack
If it must be carried outside the vehicle,a swing-away,bumper-mounted carrier,as JEEP uses for spare tires might allow for the rack,plus access to the back of the car.It impossible for me to recommend anything for the roof.
Old 01-18-2020, 11:47 PM   #8 (permalink)
If you're going to pull the bike apart why not just put it in the car?
Personally I brought a small van, pulling the bike apart is too much hassle and the bikes safer away from prying eyes.
Old 01-20-2020, 03:40 PM   #9 (permalink)
Return On Investment. How many miles, how often.
https://duckduckgo.com/?q=VW+golf+ca...+inside&ia=web
Assume some reason not to carry inside the car. Assume the car has a full aerodynamic boat tail (). Given 'roof rails of ... Jetta Sportwagen', shrink-wrap the collapsed bicycle and lash it down with an octopus bungee.
Old 01-20-2020, 07:05 PM   #10 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
A while back someone on here built an aero trailer to haul bikes that improved his HWY MPG (also a Jetta owner from memory). That would be my first choice.
I don't really understand how people lift MTB's onto roofs. That's a recipe for injuries and roof damage. Bikes are pretty awkward.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
aerohead (01-22-2020)
