Old 05-20-2012, 10:49 AM   #21 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
This works great now. I can put a picture of my truck in there, scale right on the monitor and come up with the height dimension for frames for an aeroshell. I will define some stations and use this to make a working design on paper.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-21-2012, 09:04 AM   #22 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Wow! This works great! THANK YOU!
-tanks!
-Terry
Old 08-02-2012, 10:35 AM   #23 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Just used this for a new aerocap design im working on, works great, so simple but effective! thanks
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 08-07-2012, 08:18 PM   #24 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
maybe you will like to play with equation if it is a NACA airfoil.
NACA airfoil - Wikipedia, the free encyclopedia
Is The Air template basis the upper half of a NACA 0025 airfol?
Does this template has almost the same lift (cL, coefficient of lift) than half symetric NACA?
I did some basic calculations on Solidworks CFD Flow Simulation of a wing shapped large van with flat door sides (naca extrusion) went around cd=0.37 (i don't remember lift). FAr better than a a brick shape 3D van but I got very dissapoinnted. I found airfol is very useful, on 2D shape slices to construct a 3D shape. But maybe the 3D rear wake it's wider than taller, so the more important naca shape should be zenital view of the car other than side view if enough air come from under the car to reduce lift or add aerodynamic load.
We are almost at 40ºC here, sorry if overheat some brains as well as mine because Aerodynamics is a hobby for me even in summer. so I'm sorry if there are some mistakes in my words.
Sold:
Old 08-11-2012, 09:13 PM   #25 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
First sentence;
Ecomodder.com forum users to compate shape
Should be compare.
Second sentence;
I am not the autor
Should be author.
Would it be possible to save the completed image? When I try I either get the .png or .jpg image, not both together.
It did work very well, and I need to do some reshaping between 15-35% marks. Just a tad over the line.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 08-11-2012, 10:42 PM   #26 (permalink)
skyking's Avatar
Yes, you use the "print screen" command or key to capture what is in the monitor to your clipboard. Open MS Paint or whatever editor you prefer, and paste it in there. Crop it down to what you want, and save as a handy jpg.
Here is an example below.
2003 TDI Beetle
2002 TDI Beetle
Old 08-11-2012, 11:30 PM   #27 (permalink)
Diesel
Print screen key on my keyboard doesn't do anything. Love that pic.
Boat tail project
Old 08-12-2012, 12:02 AM   #28 (permalink)
skyking's Avatar
It copies to the clipboard, then you open MS paint, click in the window there and select "paste" from the paint menu. Give it a try.
2003 TDI Beetle
2002 TDI Beetle
Old 08-12-2012, 12:36 AM   #29 (permalink)
Diesel
Ha! I thought that since nothing I could see was happening, that nothing was happening. Thanks, Man.
Worked like a charm.
Boat tail project
Old 08-12-2012, 12:46 AM   #30 (permalink)
skyking's Avatar
Schweet Pic man
2003 TDI Beetle
2002 TDI Beetle
