Old 09-26-2011, 07:41 PM   #1 (permalink)
gtkid2002's Avatar
The Bug - '69 Volkswagen Bug Base
Aeromodding Building Materials?
Just a quick thing I'd like to discuss. I was just wondering if fiberglass is a suitable material for building aeromods onto cars. It seems to me that it's light, strong, and easily doable, albeit messy as all heck. I think I recall Basjoos (I think that's his name, but the guy who build Aerocivic) used a thin sheet metal used on some aircraft. I'm not sure if that would be heavier or lighter than a good thick layer or two of fiberglass or not, but I know at least with fiberglass, it seems to me like it would hold up better than metals for a while in a wet environment. I am also not including Aluminum in that. Aluminum is rather expensive, and I don't think I could afford sheets and sheets of it.
Anyhow! Basically just asking if it's a good material to build with, and if so, why isn't it generally used more, as I seem to see a lot more done with chloroplast.
I suck at coding! Woo!
1969 VW Bug - Daily Driver
1975 VW Baja - Current Project
Priors:
1989 Honda Prelude Si 4WS (RIP)
1995 Honda Prelude Si (Traded)
1980 Fiat Spider 2000 (Sold)
Old 09-27-2011, 08:32 AM   #2 (permalink)
Why not
There is nothing wrong with fiberglass as a modding material. Done properly, I believe it is a more permanent material than coroplast. It is strong, light, infinitely malable, but it is messy, takes time to set up, usually requires sanding and painting to look good.
I think if you know it's going to be a permanent mod, fiberglass is great. If you are still in testing stages then cardboard, coroplast and duct tape are your friends.
Old 09-27-2011, 09:29 PM   #3 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by gtkid2002 View Post
.....Anyhow! Basically just asking if it's a good material to build with, and if so, why isn't it generally used more, as I seem to see a lot more done with chloroplast.
Or you could do it like this....
http://ecomodder.com/forum/showthrea...ect-13533.html
Jim.
Old 09-27-2011, 10:13 PM   #4 (permalink)
Kids, remember: coroplast is a contraction of CORrugated and PLASTic; cor-o-plast... you know, because it's just like corrugated cardboard, only made of plastic. There is no chlorine, chlorophyll, chloroform, or any such stuff in it (that I'm aware of).
Old 09-28-2011, 12:46 AM   #5 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Another inexpensive sheet that you can use is Luan sheets...about $10 per 4'x8' sheet. Just make sure you coat/paint it with something or it will delaminate...
Dark Aero-The world's first aerodynamic single wheel boat tail!
chloroplast, fiberglass, materials
