Old 03-15-2016, 10:06 PM   #1 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 16.16 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One - '24 Hyundai Ioniq 5 SEL
90 day: 97.44 mpg (US)
The left side of our new 2012 5th wheel trailer
Trailer is 29 ft long. It will be 33 ft long with the planned boat tail. Note the sloping roof which already reduces the wake area to 65 sq ft. A 4 ft boat tail can reduce this wake area to 37 sq ft.
The Following 2 Users Say Thank You to aerostealth For This Useful Post:
aerohead (03-19-2016), BamZipPow (03-16-2016)
Old 03-15-2016, 10:11 PM   #2 (permalink)
This is the right side. Trailer has two slide outs on this side. One for a wardrobe, and one for a dinette and living room couch.
Old 03-16-2016, 08:43 AM   #3 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Can you add leading and trailing edge fairings to the awning arms? I pointed those out to an RV salesman about 20 years ago and how they weren't good for fuel economy, he scoffed and said, "Man, nobody driving one of these things gives a crap about fuel economy."
And yet here you are.
Old 03-16-2016, 10:24 AM   #4 (permalink)
How do you plan to attach it? What kind of structure are you using and will it be removable? I'm sure all of us here with travel trailers are watching with great interest.
Travis..
Old 03-16-2016, 11:29 AM   #5 (permalink)
Or is it just me?
Old 03-16-2016, 12:14 PM   #6 (permalink)
90 day: 30.54 mpg (US)
I have seen plenty of trailers slope up, so it is refreshing to see one done correctly.
Old 03-16-2016, 12:33 PM   #7 (permalink)
You need to look at the photo i posted of the rear end of the trailer to see the attachment points. Basically I am going to velcro the edges to the back trailer wall. Then attach the two corners together for support. The two bottoms will rest on the two foot platform already attached to the trailer. I can use the ladder for a crossbar attachment point. I can use the crossbar for a vertical bar attachment point. I am thinking one inch foam board fiberglass ed for rigidity and strength. First we need to baseline the trailer truck mpg combination.
The Following User Says Thank You to aerostealth For This Useful Post:
Old 03-16-2016, 12:41 PM   #8 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I'm not sure Velcro will hold up in the long run over time. It's a good fastener fer mock ups and light duty but may fail at the least opportune time.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 03-16-2016, 12:51 PM   #9 (permalink)
I am concerned about that too. I am thinking of using 1x2s for the velcro which will then be attached to the panels. I am hoping the bottoms resting on the shelf will give it strength in compression and the crossbars will give it strength in tension. The corner attachments should give it monolithic rigidity.
Old 03-16-2016, 02:18 PM   #10 (permalink)
Not sure what that kind of fastener is. We just want to avoid any new penetrations into the trailer.
