Old 06-27-2008, 12:48 AM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
AFRuino?
I'm looking for something that will display the AFR on my LAF so I can see when i'm in lean burn mode and such.
Would this be possible with an arduino set up? DCB?
Thanks,
Old 06-27-2008, 01:03 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Probably, I don't know what a LAF is, but the arduino can do an analogRead of 0 to 5 volts pretty trivially, so it is well suited to a wideband. It could possibly be tuned to give a meaningful reading on a narrow band too, though that is pretty speculative. It can read the narrowband sensor turning on and off, just making sense of it is the hard part if you are not the computer controlling the mixture to begin with.
Old 06-27-2008, 01:08 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
LAF = wideband.
Interesting. Perhaps after I get the MPGuino going I'll order a second set of stuff to make my AFRuino,
Old 06-27-2008, 01:12 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
I think you just need another wire to one of the analog pins
Old 06-27-2008, 01:15 AM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Would it be that simple? It would be nice to have it on one gauge for thrift, but I'd want to see both at once...
Old 06-27-2008, 02:10 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
In concept it is that simple. It would be good to double check how much current your LAF is handling with the car computer, how much it can handle total, and how much you will be adding with the guino pin. The chip is replaceable in comparison to the LAF.
There is of course some programming involved regardless. The quick and easy way is to hijack a screen with most of what you want on it and put the AFR in a corner. like on the instant/tank screen, display the AFR instead of the mph (I assume you have a speedometer)
Also you can map it to an actual AFR on the display but memory is a little tight at the moment, so if you just remember where stoic is and some target AFRs are in terms of 0 to 1023 then that'll get you there quicker, analogRead will return 0-1023. Multiply it by 1000 and pass it to format then to lcd.print() where we are currently printing instant.mph()
Or slap another guino together and go to town :
