Old 02-26-2013, 11:41 AM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by LibbyMetro View Post
i know it automatically adjusts the ratio, but would the cone filter make for less restriction, the easier it is to suck the air in, the less the engine has to work for it, I just want to know if the mpg gain is significant or slight.
no.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-26-2013, 11:46 AM   #12 (permalink)
mcrews's Avatar
Originally Posted by Ryland View Post
There is also math to back up the intake designs that have "restrictions" compared to a simple duct that gets air from one location to another location.
Sure math is based off mathematical theory, so not everyone believes in it, but there are a lot of well written books on intake design that use math and when those intakes are put on engines that they are designed for they work better and you can design that intake to work well at high revs so you produce more power or at low revs, but a poorly designed intake will make the engine work harder to produce the same amount of power.
But some don't like to pay attention to complex things like math and instead like the simple "less restriction is better" idea instead of designing something that really is better.
discuvered that on my InfinitiQ45. Tried a cone. failed.
Infiniti spent millions on the V8 engine to get the max uot of 4.5 litrs(274 cubic inches) The result was 340hp.
I was able to get better mpg by leaving the engine bone stock and 'adujusting the nut behind the wheel' and aero mods.
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-26-2013, 02:06 PM   #13 (permalink)
Runs with scissors
Spot - '05 Scion XA
90 day: 30.33 mpg (US)
Before playing with filtration (air or oil), become familiar with microns of filtration. You can easily find out how many micron the OE recommends and if a replacement filter doesn't list, meet, or exceed the OE, stay far, far away from it. Your engine will thank you.
Old 02-26-2013, 02:59 PM   #14 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
obviously a cone filter isn't going to reduce any restriction in the intake, however, i am of the opinion that the mpg increases some people note is actually due to the WAI effect of adding one, obviously not full kits with thermal barriers.
