07-05-2010, 03:26 PM
#31 (permalink)
Originally Posted by AeroModder
Boattailing the front won't have nearly as much of an effect as boattailing the rear.
I don't know. A boat tail in the front vs stock would be like comparing the front of an F-A18 vs a Greyhound bus I would think. It doesn't matter anyway as I was just joking about the whole boat tail.
07-05-2010, 04:47 PM
#32 (permalink)
You obviously don't know. Yes boatailling both ends would be necessary if you were putting your afterburners on and flying supersonic but at driving speed its the rear where the air separates. Boatailing the back of a greyhound bus would help alot more than the front.'
07-06-2010, 10:40 AM
#33 (permalink)
You obviously don't know how to be smart, polite or civilized. I don't need or want your input.
Also, having a smaller, more aerodynamic front end would probably help a lot more than a sleeker boat tail back end for cutting through the wind, even at normal highway speeds. Perfect examples would be just about any sports car or hybrid out there compared to my Cube with it's near vertical bumper, grill and windshield.
07-06-2010, 12:40 PM
#34 (permalink)
People have tested rounded vs. blunt front ends (there's a separate thread on that), and even at freeway speeds, it just doesn't make a noticeable difference.
Think of it this way. In the front, you're pushing air out of the way. But in the back, the vaccum is sucking you back. Air is relatively easy to push, but vaccums are tough little things. Reducing the effect of the vaccum has a far greater effect than smothing out the "push" of the air, unless you're travelling well over 200 MPH.
Most rounded sports car fronts are for asthetics. If they were for function, they would have a short nose and a long tail- the opposite of what's considered attractive.
In Reason we Trust
07-06-2010, 12:47 PM
#35 (permalink)
Aero Deshi
I like short noses and long tails...I suppose this is why I like cats.
Can we test one of them in a windtunnel?
07-06-2010, 06:58 PM
#36 (permalink)
study
ChopsQube,if you'll invest the time and read through the stickys,seminars,and mod-data,you should be near self-sufficiency with respect to aero issues.
I think you've been victimized like the rest of us,with urban legends and un-supported claims about airflow 'n such.
If you'll do the homework I think you'll understand why members will be pointing at the back of the 'cube' as your source of drag.
07-06-2010, 07:25 PM
#37 (permalink)
Left Lane Ecodriver
I recently spent a few hours with Hucho, and I strongly recommend it as an introduction to vehicle aerodynamics. It contains many illustrated examples of different configurations tested in a wind tunnel.
You can gain a small improvement in drag with a rounded front end, and a large improvement in drag with a tapered rear. Low-drag concept cars invariably include both.
But I think this is a bit academic. You're not going to take the cubicness out of your Cube, are you?
