Old 10-02-2018, 05:17 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Audi A2 1.4 TDI power beast
I write short description also here what is going on with this car in my garage. Target fuel consumption for this car is 3 l/100km @ 100 km/h speed. Car is pretty close already as you can see from the calculation at the end.
- It has 1.4 TDI 90 hp versio, but I have tuned it to 130 HP with my own ecu program.
- I have changed 6 speed MYP gearbox
- Installed grill block
- Installed Tunecover hubcaps
- Optimised engine torsion value
https://ecomodder.com/forum/tool-aer...ToStep=5-200-5
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Daox (10-16-2018)
Old 10-06-2018, 01:19 PM   #2 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Veru cool project again.
What did you do with the tune?
Old 10-09-2018, 09:55 AM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'm surprised you can do all those modifications, like with the Lupo.
With yearly inspections here, any real mod would need to be removable, and need to be removed / reinstalled every year
Old 10-11-2018, 07:35 AM   #4 (permalink)
IIRC he's an engineer, so it's easier for him to go through the certification process for such mods.
Old 10-12-2018, 12:58 PM   #5 (permalink)
euromodder's Avatar
No way you could get these on the road here, even as an automotive engineer.
Old 10-12-2018, 01:15 PM   #6 (permalink)
teoman's Avatar
A3 - '12 Audi A3
What software do you ise for tuning. I plan on getting a vagcom but the logging speed is not the greatest. It is approx 1.5 secs.
Also i cannot change the parameters with vagcom.
Old 10-13-2018, 11:51 AM   #7 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
wish we had those state-side.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 10-15-2018, 01:47 PM   #8 (permalink)
It's time to pray for some of them not to be sent to a scrapyard, so when they turn 25y.o. you'd be able to import one
Old 10-16-2018, 09:28 AM   #9 (permalink)
Very impressive as usual Vekke.
Old 10-16-2018, 12:05 PM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
For the ecu edc 15 I have vag edc suite:
- put max boost to all injection levels, meaning I have driven sweeps for all injection levels and rpm range, takes really long time. Aka the full map is redone to much more leaner. First I tested is more boost better or worse and more boost is more efficienct.
- same sweeps for injection advance
- same sweeps for engine torsion value aka cam timing
For the test there was a test ecu program that inject same amount of fuel when pedal is floored. Then I had test distance where I measured time for that distance and also marked highest and lowest speeds. Test was done to both directions and summed together. This test method has proved to be quite good and reliable for testing even smallest differences like aero mods or changing tires etc.
For monitoring parameters I am using ross tech VAG com cable
aerodynamics, audi a2 1.4tdi, efficiency, fuel consumption
