Old 06-15-2016, 10:41 AM   #11 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Subscribed.
Sounds like underdriving it a little more might solve that. I can't think of a 4-cylinder out there (or 3-cylinder) other than the Insight and HCH1 that can cruise on the highway at less than 2000RPM.
MightyMirage (06-15-2016)
Old 06-15-2016, 11:21 AM   #12 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
300 Hz (corresponding to alternator speed of 6000 rpm, or engine speed of 2000 rpm)
As you can see, there is some clipping going on on the upswing of the waveform, as the on-board charge pump takes voltage from the diode drop of the MOSFET. Once the controller has built up its charge, it will apply Vgs to the gate of the MOSFET, causing it to conduct. However, this clipping really doesn't affect the waveform that much, which is why I suspect TI used that 300 Hz figure.
Precisely when the MOSFET starts to conduct, is another matter entirely. Some MOSFETs have V(gs-threshold) of 2 VDC, 3 VDC, and so on. The MOSFET I'll be using has a V(gs-threshold) of about 1.6 VDC at room temperature, and will drop to about 1.25 VDC once it heats up to 80 C inside the engine compartment.
This is what is likely to occur at 1200 Hz (corresponding to alternator speed of 24000 rpm, or engine speed of 8000 rpm)
Like I said, the waveform itself is going to start being distorted. Might be good to introduce a capacitor to filter out the added high-frequency noise associated with this distortion.
Name:	20160615 - alter1.jpg
ID:	20181   Click image for larger version
Name:	20160615 - alter2.jpg
The Following User Says Thank You to t vago For This Useful Post:
BamZipPow (07-21-2016)
Old 06-15-2016, 08:51 PM   #13 (permalink)
300Hz is 6,000 alternator RPM.
Assuming that this alternator is 6 pole. I believe most alternators are 6 pole.
Old 06-15-2016, 10:41 PM   #14 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
T Vago's test drive after said mods.......
(Totally kidding, if this is offensive lemme know and I'll delete instantly)
Old 06-15-2016, 10:56 PM   #15 (permalink)
MPGuino Supporter
t vago's Avatar
Hahahahahaha! Well, I hope that doesn't happen. There's a fire extinguisher within easy reach...
Watching a restyled Jeep Grand Cherokee burning up? What's not to like? The only offensive thing about that pic is that FCA actually decided to badge it as a Dodge Durango .
ChazInMT (06-15-2016)
Old 06-15-2016, 11:17 PM   #16 (permalink)
Aero Deshi
ChazInMT's Avatar
Honestly I got electric theory down pat on the gross voltage,current, AC, DC level but electronics baffle me. Soooo I got nothing to contribute...all I can do is sit here with a stupid look on my face.
Old 06-15-2016, 11:30 PM   #17 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Me too, over my head!
Old 06-16-2016, 03:11 PM   #18 (permalink)
MPGuino Supporter
t vago's Avatar
So this is what I think the voltage output of my modified alternator will look like.
I used 300 Hz as the example frequency. Note the notches that appear - those are when the MOSFETs begin to conduct. At this point, the MOSFETs are basically behaving as ordinary diodes.
The voltage drop that occurs across the MOSFETs allows the smart diode controllers to begin charging up their power supply capacitors, which takes about 80 microseconds. Once the capacitors are charged up, the smart diode controllers take over. The smart diodes continue to function until they are no longer forward biased, at which point they shut off - just like a diode.
Name:	20160616 - Untitled.jpg
Old 07-13-2016, 02:00 AM   #19 (permalink)
Some alternator info:
Generators | Automotive Electricity and Electronics
t vago (07-13-2016)
Old 07-22-2016, 01:34 AM   #20 (permalink)
Hi, the link with the wiring diagram is no longer valid. Please, can you post it here?
Thank you!
Stefan
