Old 01-02-2014, 06:10 PM   #1 (permalink)
90 day: 24.65 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 24.91 mpg (US)
Alternator Stopped Working (2001 VW Golf 2.0L)
My friend has a 2001 VW Golf 2.0L that stopped charging. Battery voltage was 11.5 volts unloaded, and with the engine running stayed at the same voltage. I figure he could have a bad ground, bad fuse, bad relay, or bad alternator.
I charged him up enough to get the car to a European mechanic, who wants to charge $340 just for the alternator. The mechanic also said it needed to be replaced without doing any diagnostic at all except for what I had already done.
I found a black wire going to the alternator and measured resistance to ground, and found it open. Should the wires circled in the picture below show continuity to ground?
My friend doesn't have much money, and I don't like the "replace parts until it starts working" philosophy of repair work. If you know what I can check, and where to look, that would be great.
Old 01-02-2014, 06:16 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
The smaller wire is the field excitation signal from the engine computer. The larger wire goes to the positive terminal of the battery. Neither wire should show a connection to ground.
My question is: Where is the serpentine belt?
The Following User Says Thank You to t vago For This Useful Post:
Frank Lee (01-02-2014)
Old 01-02-2014, 06:34 PM   #3 (permalink)
Yeah, where's the belt?
Also that little wire looks pulled tight to me... if there is a fault with it, I'd suspect a break in the wire right at the connector where it is pulled into a hard bend.
Oh, and friends don't let friends have newer VWs... AND THE $340 ALTERNATOR IS THE REASON WHY.
Old 01-02-2014, 08:20 PM   #4 (permalink)
Thanks guys. I'll see if I can keep my friend from the poor house...
The belt is on the alternator, it just has the ribs out.
Old 01-02-2014, 10:12 PM   #5 (permalink)
Is the belt flipped? Maybe it has no traction and nothing is spinning properly.
Old 01-02-2014, 10:33 PM   #6 (permalink)
Some serpentines ride pulleys on both sides.
regards
Mech
t vago (01-03-2014)
Old 01-02-2014, 10:36 PM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
All the alternators I have ever seen had the serpentine ribs contacting the pulley surface. The above picture is not showing that.
Old 01-03-2014, 02:15 AM   #8 (permalink)
Now I'm confused...
Looking at pictures from a Google search, it appears the belt is ribbed on both sides.
t vago (01-03-2014)
Old 01-03-2014, 02:17 AM   #9 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
EDIT: Posted at about the same time as redpoint did... hadn't ever seen a belt ribbed on both sides before... cool!
Was also trying to find a pic of the routing, and this is what I found:
No AC on that one though...
From DIY: Serpentine Belt Replacement 2.0 / 1.8T (MKIV)
Old 01-03-2014, 11:19 PM   #10 (permalink)
Update:
My friend found a re-manufactured alternator for $130 and the absurdly expensive European automotive shop charged $100 to put it in. $230 out the door... and I warned him about buying a VW. At least he is saving a ton of money in gas now that he's out of his Ford Exploder.
