08-25-2011, 06:22 PM
Slantbackd ecomodin lurkr
Aluminum framed slant back for S-10
I finally got around to posting some pics on the aerodynamic truck bed camper top I've been working on. I'm Using 1/8" 1+1/2"x1+1/2" aluminum angle for the framing. The frame will be annealed, shaped, and welded to get the proper alignment for the sides and top. Not exactly sure yet what I will use for the sheeting, but It will be fully functional with lift dampers and locks. This is just the rough draft so any and all honest criticism is appreciated.
08-25-2011, 06:30 PM
looks fast
For a shortbed,the angle looks too fast and I'm afraid you'd have separation with no chance of re-attachment.
It's better to have less slope but good flow,then you can doo even more mods later with success.
Check out the Aerodynamic Streamlining Template Part-C at Search EcoModder above.
08-25-2011, 08:13 PM
I would agree, the slope is too steep and you would get much better results with a much more shallow angle that comes down to a short vertical in the back. A window could be added to the flat back for a Prius style rear view.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
08-25-2011, 11:06 PM
Aero Deshi
Here ya go.
Get it close to this here line and yer money.
The Following User Says Thank You to ChazInMT For This Useful Post:
08-26-2011, 10:21 AM
T-100 Road Warrior
Some food fer thought...you might want to work with some cheaper materials to git yer ideal shape before you move on to more expensive materials.
My aero cap build thread...with working hatch and lifts.
http://ecomodder.com/forum/showthrea...dea-15137.html
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
08-26-2011, 03:04 PM
Thanks guys!
Awesome feedback everyone and I couldn't agree more the departure angle is pretty steep..I think I read on one of the other ecomodder's aero cap post that were looking for around 8" raised up off the rear of the tailgate, does this sound pretty realistic? And yes I'm already way over budget with $200+ in aluminum alone, but nothing is welded so it will be an easy fix. I hope to get more done this weekend, thanks again.
08-26-2011, 03:48 PM
$200+ in aluminum alone.
Find a metal scrap yard and pick up what you can.
Then return the new unused stuff you will not be needing back to the store.
Check out the chin spoiler link in my signature, a super cheap project.
08-26-2011, 05:24 PM
Yup. Too steep.
I had one like that and it was sub-optimal.
That said, it was 1.5 MPG better than a flat tonneau and 3 MPG better than an open bed.
The easy way to approximate the curves they have posted is make the top pitch at what carpenter call a 2-in-12 pitch. Do the trig. That's roughly 10 degrees.
You need the back of the thing about 8 inches about the tailgate.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
08-26-2011, 09:03 PM
#9 (permalink)
PSmodder lurker
From an old thread but may help out.
...here's a modification of a fabric convertible top keeping the best aero-slope terminating into a back. The frame could be made retractable or use a rigid frame profile (as shown on the idea). There has to be appropriate pre-bent crossbars to reinforce the shape. The immediate cons of a soft top aero-shape would be the excessive lift to weaken the structure & fabric materials.
The major themes are the aero-profile & relative ease of convertibility - completely open the back.
The donor truck I used may not be the best aero sample but it just looks damn cool to create more 'sport truck enthusiast' converts.
 [/QUOTE]
http://ecomodder.com/forum/showthrea...over-7060.html
The Following User Says Thank You to botsapper For This Useful Post:
08-26-2011, 11:13 PM
#10 (permalink)
Aero Apprentice
It's been a while since I've posted here, but I'm still using my AeroLid to this very day, and it makes an unquestionable 10-15% difference on fuel economy. I agree with the others that you need to raise the profile of the rear of the shell. If you look at how I did it, I used a separate rear profile to raise the separation line above the origional tailgate line.
Good on you for using top quality materials too, the cover will last a long time if you do it right. I'm glad that I skinned mine in coroplast rather than plywood or building wrap plastic, it's stood up well in over a year and a half.
Here's pics of my build http://ecomodder.com/forum/attachmen...1&d=1272764200
Hope this helps,
Swede
1994 electricfly EV conversion 36V/450A/60km/h
1997 Suzuki Sprint hatch (parts car?)
1998 Geo Metro sedan 1.3L auto (the wifes)
2009 GMC Sierra 27us/mpg best yet (still workin on it)
The Following User Says Thank You to swede For This Useful Post:
