Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 02-19-2025, 04:29 PM   #1 (permalink)
Best Geometry for a Reverse Tilting Trike
The geometry is for a 4 meter wheelbase but is generalizable. Or maybe a tandem two-seater.
Logic (02-21-2025)
Old 02-24-2025, 11:15 AM   #2 (permalink)
Clear and accurate testing is always welcome. Equal length parallel suspension arms give the tilt geometry. Camber at 0 is fine. The Caster on the early Chevrolet Monte Carlo was 11 degrees tilted to rh rear. Positive or Negative castor works. Our motto is test don't guess.
