Old 01-26-2008, 09:44 PM   #41 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Good! It is a stick.
A T56 will not be an easy swap but it has a 0.5:1 sixth gear and you should be purring down the road 1500 RPM @60 MPH. That will help a lot.
Fourth is straight through and you should still get good quarter times. Few cars get beyond fourth in the quarter.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-26-2008, 10:01 PM   #42 (permalink)
I'll actually be following this thread for selfish reasons. I have a 1969 Firebird convertible that I'm trying to maximize economy. Very little assistance or tolerance for mpg talk in a lot of the forums. I just found the site today linking over from a CRX forum and plan to do a lot more exploring. Hope to share what I've learned studying this subject over the last six years or so. Good luck with the Stang and thanks for the welcome guys!
1991 CRX Si 42+mpg @290k miles
2002 New Beetle TDI
Many classic cars...
Old 01-26-2008, 10:22 PM   #43 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
It doesn't seem to be too bad, but it is pricey, so swapping/flipping fifth on a T5 would probably be cheaper but way more labor intensive.
Edit- A 3.08 rear end swap seems to be the easiest and most economical, but that'll hurt acceleration, so a taller fifth in a T5 seems to be the cheapest and best for performance provided the owner is handy and there's enough room in the case for the taller OD gear.
Old 01-27-2008, 11:03 AM   #44 (permalink)
Actually Cobras came with a t-56 so it might not be a bad swap. Six gears is like having your cake and eating it too- super low gears with a deep overdrive.
2002 New Beetle TDI
Old 01-27-2008, 12:18 PM   #45 (permalink)
what exactly is a T56?
Old 01-27-2008, 12:41 PM   #46 (permalink)
Big Dave's Avatar
A T-56 is a six speed made by Tremec. It is used on a lot of high performance cars. Essentially, it is a close-ratio four speed with two overdrives on it. Fourth is straight-through. Fifth is 0.72:1 IIRC, and sixth is 0.5:1. It does exactly what you are looking for - gives you great quarter-mile performance AND low-revving economy gearing.
Corvettes do not use the T-56 but they have been in Camaros, Firebirds, GTOs, and Mustangs for years. They will probably be availalbe on the Pontiac G8. You can get rebuilt or remanufactured T-56s if cost is a big item.
With OEM-sized rubber you can expect 1200-1500 RPM @ 60 MPH depending on your axle gearing.
I was always under the impression that a T-5 is a throwaway and any work you put in it will cost more than it is worth.
The other workable alternatives are:
Regear the car to 3.08 or 2.73.
Install a Gear Vendor or US Gear overdrive
If I had a pony car I loved I'd be thinking T-56. I even briefly thought about one for my diesel but it is not heavily enough built to take the sustained loading a diesel can put on it.
4" Slam
Old 01-27-2008, 12:50 PM   #47 (permalink)
Big Dave's Avatar
My bad!
Correction to previous post.
The overdrives for a regular T-56 are 0.8 and 0.62.
The overdrives for the "Chevy/Viper" T-56 are 0.72 and 0.5.
Maybe I need to think about a "Viper" T-56. I have been thinking about a US Gear or Gear Vendor overdrive for my diesel but if it can live with 650 ft-lb, that's more than my diesel makes. A USG or GV goes about $3500 installed.
4" Slam
Old 01-27-2008, 02:00 PM   #48 (permalink)
Actually the Vette uses it too in addition to the new GTO. Small variations between all the applications though. Check www.sixspeedinc.com. They have a great reputation on LS1tech.com. My 99 TA uses the T-56 and is big factor in its performance in mileage, acceleration and ridiculous top speed.
Should run you about 1500 without a core I believe. Not sure what else is involved for the late model Mustangs, but like I said the Cobra ran it so it should be a bolt in with the right parts. Check the Ford boards out to see.
2002 New Beetle TDI
Old 01-28-2008, 11:39 AM   #49 (permalink)
i have a low profile grill insert installed on the stanger-banger... got it done this weekend... drove to work successfully and it stayed attached (which is amazing... FULL OPEN grill... nothing to attach to, had to be creative)
Old 01-28-2008, 06:20 PM   #50 (permalink)
Big Dave's Avatar
DD Performance offers T-56 kits esecially for Mustangs.
I wonder if one of their T-56 (650 ft-lb) will work with my diesel?
4" Slam
