Old 10-15-2013, 01:03 PM   #1 (permalink)
topcat's Avatar
Celica VVTI - '05 Toyota Celica GT VVTI
90 day: 41.89 mpg (US)
Xgauge: timing advance: IGN / RPM
I know that the scangauge of timing advance (IGN) can help find a good efficient place to run. The higher the advance, the better. But I also find it increases with speed (& RPM). To remove the dependency on speed, we could do IGN/RPM as an Xgauge. Can anyone clever work out how to do it?! Preferably for the ISO comms protocol. Thanks!
Old 10-19-2013, 04:39 PM   #2 (permalink)
topcat's Avatar
To answer my own question, from what I read, it seems that the xgauge will only allow you to use one variable per xgauge. You can tweak that variable with a gain and offset, but you can't take two variables and do X/Y.
E.g. it works like y=mx+c where m is gain, c is offset, x is input variable, y is output of xgauge.
Maybe someone might know a clever trick to get around that?
Old 10-19-2013, 05:31 PM   #3 (permalink)
...beats walking...
Sounds like a task for one of the aftermarket "add-on" OBD reader programs that use a laptop computer to both collect & analyze data.
