08-07-2010, 08:23 PM
Fully Charged - Test Drive of the Nissan Leaf
The Following 3 Users Say Thank You to Patrick For This Useful Post:
08-07-2010, 10:33 PM
...beats walking...
...uh, which was "fully charged"? the car or the driver?
...maybe I'm jaded, but that was a rather bland, pabulum-laced, ingratiating, review from my perspective.
08-08-2010, 08:58 AM
Agreed. Plus i simply could not believe my eyes at the sight of a piece of junk cheap STARTING BATTERY!!! I mean for crissake would 4 headways have blown the r&d budget
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
08-08-2010, 09:18 AM
Left Lane Ecodriver
That wasn't a starting battery... that was a lead-acid 12V accessory battery. Just a buffer for the DC/DC converter. If the final version of the car ships with one, I'd replace it with one of these little guys:
Also, while the EV1 was a new car from the ground up, the Leaf rides on a modified Versa platform. There's nothing wrong with platform sharing, just things wrong with Llewellyn's facts, as usual.
08-08-2010, 09:31 AM
I appreciate it wasnt there to start an engine but unless my eyesight is totally shot it was a starting type battery. ie cheap paste plates not deep cycle. Not even agm.
www.evbmw.com
08-08-2010, 10:19 AM
Left Lane Ecodriver
Rectangular plates, six service ports... you're right, it's a floodie. And it looks like it's the same size as a Honda Civic's battery.
The Following User Says Thank You to RobertSmalls For This Useful Post:
08-08-2010, 10:25 AM
Nice to know i'm not totally mad I have no problem with them using an accessory battery as with the key off the traction pack will (should) be offline so it picks up housekeeping loads. But why not a deep cycle gel or agm at the very least?? Or ideally a small lithium pack? Even my ultra budget conversion uses an odyssey pc1500!!!
www.evbmw.com
08-08-2010, 01:28 PM
One of those little critters from that pic is only 7.2 Ah. Might be a wee bit too tiny...
08-08-2010, 03:33 PM
#9 (permalink)
Pokémoderator
Patrick -
Pretty neat. Definitely a friendly interviewer as others have said, but I still learned some leafy details. I want to see some commuter studies with the Leaf to see if its driving range holds up under real-world conditions.
CarloSW2
08-17-2010, 12:48 PM
#10 (permalink)
