Old 04-30-2009, 11:55 AM   #1 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
Using vortex generators on my car?
Hello all,
I've got a Vauxhall Astra ECO4. The Astra is a common as muck car in the UK, but the ECO4 is a rare factory modified Astra to improve areodynamics. Basically, Vauxhall stuck on underbody panels, spoiler, thin high pressure tyres and a very low ratio gearbox. As the spoiler is only found on the ECO4 - the standard Astra spoiler is very different, I can believe that it improves areodynamics, so would using vortex generators to improve flow towards the spoiler help?
Here's a couple images of the back of my Astra, and here's an image of the standard spoiler on someone else's Astra.
Thanks very much for your time in advance!
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Old 04-30-2009, 01:11 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
The value of vortex generators at all is in debate, I think, but I'll let someone else chime in on this one.
Old 04-30-2009, 02:12 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Eddles -
I have airtabs (see here), but I can't prove that they help.
Mine are designed for the end of truck trailers, i.e. boxy-ended shapes.
My advice is that if you have a boxy car like a Honda Element or a Jeep, they could help :
If you search this site, you will be able to find lots of "DIY" vortex generators that will keep your wallet plump and happy.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Eddles (09-06-2009)
Old 04-30-2009, 03:34 PM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Whereas my experience with boxy vehicles and a sedan is they made no measurable difference - http://ecomodder.com/forum/showthrea...fect-6381.html and http://ecomodder.com/forum/showthrea...olla-2390.html
(Although that's with AirTabs, not delta style VG's)
I get the impression that VG's are seen by many as a magic bullet. They're not.
Recall that even in a scientifically optimised deployment of delta wing style VG's, Mitsubishi's results were a reduction in the coefficient of drag of just -0.006 .
Eddles (09-06-2009)
Old 04-30-2009, 04:31 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
MetroMPG -
Yeah, here's another way to quote myself :
My advice is that if you have a boxy car like a Honda Element or a Jeep, they *might* help
CarloSW2
Old 04-30-2009, 05:09 PM   #6 (permalink)
Hi,
I found that AirTabs added drag to my Scion xA, and I got slightly worse mileage when they were on the car.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 70 03-14-2012 12:25 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
