Old 05-22-2013, 05:10 PM   #11 (permalink)
different 'Template'
MetroMpg mentioned this and it might help.
At the thread,'Aerodynamic Streamlining Template Part-C' you'll find a more 'current' profile which you might want to compare the VX to.
Your VX's roof appears to be a good 'fit' to the original 'Template',but if the 'faster' roofline will integrate as well,you might see an advantage.
You'll have to make the call.
Old 05-29-2013, 10:01 PM   #12 (permalink)
Civic - '93 Honda Civic VX
90 day: 74.19 mpg (US)
I made some good progress over Memorial Day Weekend. The new rear quarter is welded in place now. Visually it probably looks the same as the last pic but there it was just fitted in place. Now it is welded and very solid. I gave it some additional seam welds around the wheel arch and suspension mount points. Now I have to seal the seams and do some body filler work on the remaining rust.
I will look at the new template C and see if it can help me with the Kammback.
The Following 2 Users Say Thank You to mloveland78 For This Useful Post:
aerohead (07-31-2013), California98Civic (01-03-2014)
Old 07-30-2013, 09:14 PM   #13 (permalink)
Blue!!!
Its finally back together (Mostly) and Blue! Bright Island Blue Metallic to be exact. I still have a lot of work to do putting the inside back together and doing the mods, but I got my MPGuino installed. Averaging over 60 on the highway with "normal" driving.
The Following 5 Users Say Thank You to mloveland78 For This Useful Post:
aerohead (07-31-2013), California98Civic (01-03-2014), Cd (01-04-2014), mikeyjd (09-05-2013), Stacygifford (08-27-2014)
Old 07-30-2013, 09:23 PM   #14 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
awesome! it looks fresh from the factory
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 08-08-2013, 05:32 PM   #15 (permalink)
Cardboard Voila!
Starting to work on the Cardboard template for the Kammback. I already have a template cutout for the wheel skirts. Going to transfer the template to ABS plastic once I am happy with the fit. I also got my MPGuino permanently installed in the dash where the rear defroster switch used to be.
aerohead (08-10-2013), California98Civic (01-03-2014), Cd (01-04-2014), Jyden (08-08-2013), mikeyjd (09-05-2013)
Old 08-08-2013, 06:03 PM   #16 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
awesome placement of the MPGuino...however, since it's recessed into the dash, do you no longer have access to the buttons to allow you to reset your tank and current mpg?
Old 08-08-2013, 06:05 PM   #17 (permalink)
The buttons just poke through the top of the trim on that part of the dash enough to push them.
Old 08-08-2013, 06:06 PM   #18 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
ooh i see, i couldnt see the buttons from your picture.
Old 08-09-2013, 12:28 PM   #19 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Looks phenomenal. Block that grille!
Old 08-11-2013, 08:50 PM   #20 (permalink)
Ask and Ye shall receive
So I spent some time this weekend working on the VX. Had to replace some non-aero stuff like door gaskets and windshield trim. I also got around to hacking off the driver's side mirror which was already broken and useless. I replaced it with a mirror that seems to have been designed specifically for us Ecomodders. A blindspot mirror made by Pilot I picked up at P*pb*ys auto parts.
It sticks to the windshield with included double sided tape. It fits great and works great and was only $15.
Also made the grill block out of ABS plastic with a tab and slot method of attachment so I can easily switch it out in the winter.
The Following 4 Users Say Thank You to mloveland78 For This Useful Post:
aerohead (01-02-2014), California98Civic (01-03-2014), Cd (01-04-2014), mikeyjd (09-05-2013)
