Old 11-13-2009, 07:00 AM   #11 (permalink)
Two_Weeks's Avatar
Luigi - '94 Fiat Uno 60D Start
90 day: 45.18 mpg (US)
I managed to find the original MPG figures for this car, so have updated Luigi's stats, and now added a sig. Hopefully it should appear below......
Old 11-14-2009, 03:33 PM   #12 (permalink)
The PRC.
Hi,
Have you adjusted your MPG for the taller tyres ?
I believe also that a door mirror is a requirement of the MOT test, may be worth checking before you go down the camera route.
Cheers
A.
diesel, fiat, uno
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 12:15 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
