Old 02-16-2018, 09:13 PM   #11 (permalink)
What is the advantage of the wheel? When it isn't touching the ground, it's placing extra stress on the frame, and when it is hitting the ground, it's due to lack of clearance, which places a great deal of stress on the frame.
OK, forget the first diagram. I've changed it into a trailer that has freedom of movement only up and down, and left or right. (See permalink #13)
Old 02-16-2018, 09:17 PM   #12 (permalink)
Originally Posted by oldtamiyaphile View Post
Trailer hitches are designed for down loads of around 200lbs. This design would be a good way to bend chassis rails or rip the attachment points clean out of the chassis.
I've abandoned the first idea. See my new diagram at permalink #13
Old 02-17-2018, 12:14 PM   #13 (permalink)
Let's ignore, for the moment, the shell of the trailer. This is the mechanism that will allow the trailer to move both up or down to follow grade changes, and left or right, for turns, and at the same time, without allowing the single wheel to fall on it's side. I was having trouble envisioning how to keep the movement centered on the same vertical line, but I think I have it now:
Name:	2011 prius U-Joint.jpg
Old 02-17-2018, 03:04 PM   #14 (permalink)
I'm skeptical. The roll resistance has a 0-length lever arm.
Why? You could have a one foot lever-arm between the horizontal and vertical hinge, with a 16" transition piece. And two hinges widely spaced hinges, both horizontally and verticall, enableing lighter construction.
That would mean a transition piece between the car body roper and the tail, but the gaposis would be on the top at the front and on the sides at the back
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
