Old 07-27-2010, 12:43 PM   #1 (permalink)
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
Another silly question about wheel covers
I was just sitting here thinking about some pizza pan wheel covers and after reading some posts last night it seems there may be a brake overheating issue there. Mine would have to mount to the wheel hub (dome shaped) cap in the center, probably with two bolts. Could the pans be mounted with spacers to give a small gap (1/8"-1/4") between the edge of the pan and the wheel or would this defeat the whole purpose? It seems like it would give some advantage for "smoothness" while still having a small place for airflow to relieve the heating problems. Or am I just dreaming?
Old 07-27-2010, 01:07 PM   #2 (permalink)
Unless you're driving down a mountain, your brakes should cool themselves fast enough. Plus, an ecodriver should strive for limiting brake use as much as possible in the first place.
I can't comment directly since I don't have full moon covers on any vehicles, but I've never heard of anyone having problems.
Old 07-27-2010, 03:16 PM   #3 (permalink)
...beats walking...
...unless you're slaloming or hill-climbing, there should be no problem.
Old 07-27-2010, 03:28 PM   #4 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Especially if you have aluminum alloy rims (standard I believe on the splash) overheating is highly unlikely unless you go downhill with heavy loads frequently.
The aluminum alloys will dissapate the heat very readily.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 07-27-2010, 04:18 PM   #5 (permalink)
It's MPG Season
aburk4's Avatar
...an ecodriver should strive for limiting brake use as much as possible in the first place...
If you're an "ecodriver" and you overheat your brakes, then shame on you. I would just like to point that out.
I don't think this is something you need to worry about.
Thanks and Good luck!
Old 07-27-2010, 04:55 PM   #6 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
When I had full discs on mine, a friend raised this question. To settle it, after a trip I reached around the back and grabbed onto the brake disc with my bare hands. It was only slightly warm, no more than you'd get from sitting still in the sun.
not a problem
There is still full air flow around the back of the wheel.
Old 07-27-2010, 06:58 PM   #7 (permalink)
N.B.--Most slaloms are too short to build significant heat in the brakes. Hillclimbs can be a different matter, but the brakes aren't worked super hard on the uphill sections.
-soD
Inside wheel covers ? tollo Aerodynamics 14 04-20-2010 06:22 PM
aero wheel covers? gone-ot Aerodynamics 2 04-06-2010 06:59 PM
OEM Near-Aero Wheel Covers Rokeby Aerodynamics 15 10-21-2009 11:37 AM
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
