Old 10-19-2011, 05:37 PM   #1 (permalink)
OurInsight - '06 Honda Insight
Fuel Economy Impact of New Tires
Just replaced my old Bridgestone RE92 LRR tires with a new set of same tire. Doing a bit of extrapulating of my baseline data, it looks like I lost 2-4 MPG.
If these tires don't improve shortly, I'm gonna shave them down to 4-5/32" , like we do on race tires for the Miata
Old 10-19-2011, 09:04 PM   #2 (permalink)
It always takes a while for new tires to "wear in" and drop down to their proper rolling resistance. I think it took something like 1K miles for the Hankooks that I put on my old car?
-soD
Old 10-19-2011, 09:57 PM   #3 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Remember that you were most likely seeing inflated (forgive) mpg numbers with your old tires. More rubber was worn off of them making them smaller and lighter.
Old 10-19-2011, 10:20 PM   #4 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
I lost about 1 MPG on my Mustang for one fill-up when I "re-tired" it in May.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 10-23-2011, 08:51 PM   #5 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
Shaving your tires will reduce treadlife and force you to buy new tires prematurely. Is the increase in mpg going to offset the price of new tires? I suggest giving them a couple thousand miles of break in before you do anything drastic.
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
Old 10-23-2011, 10:20 PM   #6 (permalink)
Evil Genius
LPG FTW - '96 VW Cabrio
The Green Bimmer - '95 BMW 525i
The White Bimmer - '94 BMW 530i
i agree with F8L. the benefit youd gain from shaving the tires would likely offset the value due to the cost of new tires sooner. if they dont yeild the results u want maybe they changed something in the manufacturing process since the purchase of the old tires that is having an impact on the new ones.
Old 10-23-2011, 11:33 PM   #7 (permalink)
Hubert Farnsworth's Avatar
Planet Express Ship - '94 Geo Prizm LSI
90 day: 36.57 mpg (US)
Lower tread depth = fewer revs per mile = artificially increased mpg figure as the odometer turns slower, so the effect of the new tires is to increase the outer diameter by the increased tread depth, which means more revs per mile by a couple, and then until they are broken in they will not have reached their ideal rolling resistance until then.
However if you were to shave them back down to a lower tread depth it would only help in the dry, ruin wet and or snow traction, and cause you to need to replace tires even sooner.
Old 10-24-2011, 09:11 AM   #8 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Mathematically the contribution of tread depth to outer diameter is pretty small. Ball park maybe one percent over the life of the tire.
Recreation Engineer
Old 10-24-2011, 10:04 AM   #9 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Hi Jim,
Hold tight and wait a while.
The tire rubber will get harder after 20 or so hot/cold cycles from running the car, then letting it sit and tires cool.
Whenever I put a new front tire on the motorcycle, I can really feel the grip of the new tire on the road during the first few rides. The handle bars are noticeably harder to push for turns as well.
After those hot/cold cycles are done, the tire feels much less sticky when turning.
The same thing will happens with our Insights after the tires harden somewhat.
Jim.
Old 10-24-2011, 08:40 PM   #10 (permalink)
Originally Posted by 3-Wheeler View Post
Hi Jim,
Jim.
Yeah, I suspect as much myself. It is probably a breakin process which will take some little bit of time. The actual change in diameter between old and new is so negligible that won'g be likely to have any effect.
