Old 09-22-2021, 04:04 PM   #11 (permalink)
I enjoyed, and still have, an aftermarket five-speed conversion. With a conversion from swing axle it would happily live in my Superbeetle.
Cheap/simple: Unpainted stainless steel body, flat glass, ceramic engine block running at high temperature.
Old 09-23-2021, 02:28 AM   #12 (permalink)
That would be quite interesting, yet if I were building some sort of Beetle replica I would nowadays be more inclined to use some fiber-reinforced plastic.
Just the block made out of ceramic? Well, maybe some water-cooled heads such as those fitted to some engines adapted for usage in ultralight aircraft could be interesting to decrease NOx emissions.
Old 09-23-2021, 03:17 AM   #13 (permalink)
Offenhauser built monobloc engines from 1930, no separable head.
Porsche 3D prints pistons with internal oil cooling passages.
I believe high operating temps benefit the thermodynamic cycle.
Old 09-23-2021, 01:25 PM   #14 (permalink)
Avoiding head gaskets, which are prone to damage, is a good thing. No wonder Citroën resorted to threadable cylinder heads for the 2CV for instance, even though it was not so similar to the monobloc Offenhauser. But I guess it would be a PITA to overhaul a monobloc engine, or just replacing the valve seats or guides.
Old 09-23-2021, 05:08 PM   #15 (permalink)
Except that the head doesn't remove, the valves either come out the side like a "F" head or out the cylinder with the pistons gone. I know the offy was a "F" head for a while. A "T" head would be interesting.
Old 09-23-2021, 11:21 PM   #16 (permalink)
Overhead cams seem to be the best solution for a monobloc engine.
