Old 10-25-2014, 06:13 PM   #31 (permalink)
The control modules on a motorcycle or scooter, if they have one, will likely be much different than on automobile. Emissions and fuel management modules are usually vendor specific. Check with a dealer or tuner in your area for info on the newer systems (1998 and up). Ignition systems went from breaker points to CDI, and then came fuel injection. I would look at flow gauges from scientific or industrial supply firms
The Following User Says Thank You to Grant-53 For This Useful Post:
SwamiSalami (10-28-2014)
