Old 08-05-2008, 05:10 AM   #1 (permalink)
Tracy - '00 vauxhall corsa
EOC seems pretty violent?
hi
this week i have been mostly doing EOC. i've noticed you have to pick the right gear to re-start the engine in and you have to remember to put the key back to iii(run) or you have problems.
even when you do it right though it can still seem pretty violent on the engine
-are you sure it is not exsesivly wearing the enging or transmission?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 08-05-2008, 05:35 AM   #2 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
I have found out that for my engine 5th gear always is the best to bump start in and I try not to bump under about 15mph or it gets a little shaky and is alot tougher to do smoothly.
practice makes perfect. make sure to only let out the clutch a bit to "bite" and spin up the engine then push the clutch back in.
my 2 cents
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 08-05-2008, 06:17 AM   #3 (permalink)
greenitup's Avatar
Truck - '97 Ford Ranger
90 day: 30.32 mpg (US)
I alway put my key to iii after i turn it off, because otherwise it doesn't keep track of the mileage and therefore i can't compare tanks properly so i like that convenience. I drop it down into overdrive (5th) when i want to pop it in. I then push it back in when i see my gauges move (battery level and heat of engine) If you practice enough then you should feel very little.
Old 08-05-2008, 06:43 AM   #4 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I'm getting good with a bump-start technique-- at around 25mph, I start it in fifth, by gently engaging the clutch, then immediately disengaging it, as soon as the engine fires up. It works pretty well, and I'm able to do it pretty smoothly.
Old 08-05-2008, 07:01 AM   #5 (permalink)
Modified Driver
Twerp's Avatar
Location: South Western middle of nowhereish New Hampshire
Frozen Tundra - '03 Toyota Tundra 4WD SR5 Access Cab
90 day: 26.51 mpg (US)
Red Skateboard - '91 Honda Civic DX
90 day: 45.49 mpg (US)
It took me a while to figure this out, but there should be nothing violent or abrupt about restarting your engine. I usually do it somewhere in the 30s using 5th gear. Here's the key, you don't let the clutch all the way out and you put it back in before the engine actually starts. It's just a little rub of the clutch plates and nothing more. It needs to be done kinda quickly. I just jerk the pedal back part way and then push it back in. The engine starts half a second later. I can do this almost perfectly and it just feels like I tapped the brakes for a split second. It takes a lot of practice, and quite a bit of skill, so don't be afraid to use ol' sparky to fire up your engine if you need power in a pinch. Obviously the key has to be in the "run" position and I would recommend using extreme caution so as not to engage the steering wheel lock when turning off your engine. Some cars engage the steering lock immediately after turning the key off.
Old 08-05-2008, 08:29 AM   #6 (permalink)
homeworkhome53's Avatar
Workride - '07 Chevrolet Aveo5 SVE
90 day: 51.74 mpg (US)
If you put in a kill switch you don 't have to touch the ingnition switch and the odometer continues to total and the lights stay on after dark. I wired mine into the fuel fuse in the engine compartment (each car will be different) and it works great. About $10 for a switch, inline fuse and wire. I put it right beside the gear shift on the consol. I always bump in 5th and do it between 15 and 35. I push the clutch in immeditaely after starting if I'm coming to a stop, otherwise no. The engine starts very smoothly.
homeworkhome53
Old 08-05-2008, 11:01 AM   #7 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
How to smoothly bump start / clutch start an engine
Old 08-05-2008, 11:18 AM   #8 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
what about for those of us with automatic transmissions...when I shut off at a light I put it in neutral to restart.
If I mounted a kill switch to the shifter I could put it in neutral and kill the fuel while rolling...but will it restart once I let off the switch because it is an automatic?
Will that cause harm to the transmission puting it back in D while rolling at 25-30mph? or less?
Old 08-05-2008, 01:00 PM   #9 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Try it and see if there is any harsh engagement. I go from neutral into gear at 50-55 mph quite often (10 times a day) and if I don't rev match its a little harsh but no different than a 3/4 throttle upshift. The Neons auto is an understressed 3 spd with a good reputation in turbo drag racing applications though.
If I was driving a 90's Dodge minivan I wouldn't play around with coasting in neutral so much although at 25 mph I doubt that would hurt any transmission unless it tries to go to 1st gear or something silly.
Ian
p.s. I just checked out your garage, your car might have an early relative of the Neon tranny, plus if you are able to do tranny swap then I would neutral coast all day with that auto until you swap it out
Old 08-05-2008, 01:18 PM   #10 (permalink)
I read an article about someone building an early 90's Nissan SE-R for road racing using a stock transmission...but he did some research and found that there were several gear ratios offered through out the run of the car...and picked all the individual gears that would give him the best performance.
Now with my car...the research I've done has shown that the 4spd actualy had a bit better economy. (5spd probably was closer ratios) I'm wondering if I can build a frankenstein tranny that would be a 5spd...but be the most economical gears from the 4spd 5spd and a neon 5spd as you mentioned...with the lowest 5th gear/final drive that I can find.
I'll give the neutral coasting a try and let yall know how it goes.
NO Damage to auto transmission by EOC ScottC33 Hypermiling / EcoDriver's Ed 35 07-09-2009 02:42 AM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-21-2008 11:25 PM
Metro EOC switch how to bbjsw10 EcoModding Central 10 07-18-2008 09:05 AM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 08:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
