Old 08-06-2008, 10:39 PM   #1 (permalink)
Lancer - '00 Mitsubishi Lancer GLX
90 day: 30.28 mpg (US)
are there race style driving techniques for hypermiling?
hi,
there are those things such as heel and toe, left foot braking, cadence braking, threshold braking and many others in the racing world. does this have a place in hypermiling?
Old 08-06-2008, 10:54 PM   #2 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
never touch the brake pedal if you dare!
Nissan Versa Aeromods
Old 08-06-2008, 11:41 PM   #3 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Actually....if you watch NASCAR you see them doing EOC when they are short on fuel during caution laps.....at their last race a few cars ran out on the last few laps and at least three coasted across the finish line on the last lap!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 08-07-2008, 12:06 AM   #4 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
I thought NASCAR was trying to put a stop to that after Earnhardt Jr did it and won?
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-07-2008, 02:52 AM   #5 (permalink)
there are some vehicles that cannot eoc because of the following:
1 - vacuum is lost, thereby reducing braking force when repeatedly pumped
2 - power steering is lost because oil pump does not recirculate the fluid
3 - some steering columns lock when key is in acc
Old 08-07-2008, 04:22 AM   #6 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
I'm not an hypermiler, only an beginner ecodriver , and I never raced, so...
IMHO only the way to take curves (with the biggest turning radius) may apply because you can save momentum created by your gas burning. I commonly take roundabouts (France has so many of them...) at 40km/h (25 mph) if nobody is too close to me and I know this roundabout isn't too small for the speed (ie has a big enough radius, or has two lanes).
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 08-07-2008, 04:50 AM   #7 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Draft.
Old 08-07-2008, 05:29 AM   #8 (permalink)
They did have a talking to about his method of coasting......he passed the pace car on a few occasions...that is a no no, but they have no specific rule against it....Jr did noy take a victory lap and his car died on the way off the track.
95 Neon-43 mpg
Old 08-07-2008, 09:08 AM   #9 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
That's a smooth move on his part. Really smart racing. Good for him. I plan on getting into endurance racing in 2 summers. I will have to keep that in mind. There are places on a road course where you could reasonably drive without the engine on for a few seconds at a time without losing much ground. My ignition and starter are on dash switches, so it would be cake.
Old 08-07-2008, 10:27 AM   #10 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
The only "racing" technique I use hypermiling is choosing the ideal line for a corner. Typically starting wide going tight into the apex and then wide out without getting on the brakes if possible. My rules are no tire squeal and no cutting into other lanes.
I also have a gravel road short cut on my commute with 3 nice 90 degree bends that I can see if anyone is coming. I may occaisionally do some left foot braking with the Neon so I can enter the corner briskly and then put the car a bit sideways if needed to hold my line. Sounds kind of dangerous but I can say I haven't even come close to losing control and it will be only my dumbass in the ditch if things go bad somehow. This mostly for fun though as being on the gas and brake at the same time probably negates my higher entry and exit speeds...
MazdaMatt,
I'm sure there are ways to use less gas while maintaining most of the speed while racing. Probably slow in and fast out, rolling on the throttle instead of mashing it and avoiding big drift angles while accelerating would cover most of it I'd think.
vtec-e/lean burn driving techniques Vince-HX Hypermiling / EcoDriver's Ed 17 05-16-2011 05:29 PM
I've drastically changed my driving style and getting results! Chris D. EcoModding Central 45 07-23-2008 04:13 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
