Old 08-15-2013, 12:28 PM   #1 (permalink)
Joggernot's Avatar
Lower grille blocked
I finally blocked the lower grille on the Honda using Corrugated Plastic and duct tape. I also looked up towing in the owners manual and it gave a distance that it could be towed (EOC) after the transmission had been run to circulate the fluid. I'm keeping the mud flaps on for now.
So, on my short almost daily run where I would get 22-24 mpg (best), I got 26.2 mpg (ScanGageII) for both runs. Highly unscientific, but obvious to me. I think these were good changes.
Joggernot
Old 08-15-2013, 09:49 PM   #2 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
Better get that duct tape off and use blue painters tape. What was the towing distance?
Don't know why it says 00, it's a 95
374,000 miles and tired.
Old 08-16-2013, 09:59 AM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
you DO NOT want to Engine Off Coast with an automatic. period.
Numerous discussions on this topic.
Towing has NOTHING to do with Engine off coasting.
Automatic tranny coast in neutral with engine ON.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-16-2013, 02:41 PM   #4 (permalink)
Joggernot's Avatar
Duct tape changed to blue painters tape. The silver duct tape on a silver truck and car looked a lot better, though.
The owners manual says towing with front wheels down for 50 miles at 35 mph. My EOC is at 35 or less, so I "assumed" it would be ok. Since you people are the experts, I'll limit myself to Engine On coasting.
Thanks for the fast and pertinent responses!
Old 08-16-2013, 02:42 PM   #5 (permalink)
mcrews's Avatar
duct tape tends t oleave a sticky mess. hard to clean off.
ECO MODS PERFORMED:
First: ScangaugeII
Old 08-16-2013, 03:15 PM   #6 (permalink)
Joggernot's Avatar
Yes, I knew about cleaning off the duct tape, but normally acetone works, as it did this time. Hope there isn't a problem with the blue tape. Just for info...naptha works on almost all other tape residues/glues, but not on duct tape.
Old 08-16-2013, 04:26 PM   #7 (permalink)
Exceptional Member
I EOC the auto in my 95 accord, sometimes up to 70mph and for distances over 2 miles.
Old 02-08-2014, 09:12 AM   #8 (permalink)
Joggernot's Avatar
With the temperatures in the 30s I blocked off the upper grill as well. That was too much. Temperature went over 220°F, so I had to stop and pull out the foam blocking the upper grill. Next experiment will be to block the upper and open the lower to see what the water temperature does.
