Old 09-05-2014, 11:56 PM   #11 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Cobb View Post
5 miles?!?!?!? Hell Yeah the grid charger will give you wicked mpg even without lean burn. Since it wouldnt draw much power you could power it with an inverter and deep cycle battery to charge while at work.
I have access to electricity at work at 4 days a week now, unless the generator dies at the other site, then I would only have power 3 days.
Old 09-06-2014, 12:44 PM   #12 (permalink)
You going to use a gas generator to grid charge your hybrid?!?!?!?
Hey, as long as the gas is free.
Old 09-09-2014, 01:46 PM   #13 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I don't think there's a good way to tell how full the Insight's battery is. Even the computer can't tell, so one problem you'll have by topping it off at night/at work is that when you get in it to drive, the computer will be under the assumption that it's at the same capacity as when it was parked and will charge/assist based on its assumed battery level. I'm considering trying it anyway, by putting my grid charger on a timer and only adding a couple of hours of charge.
Old 09-09-2014, 05:50 PM   #14 (permalink)
SOC is somewhat subjective. One way to guesstimate it is by voltage. For the gen 2 109 volts is like 90% 117 is 100% according to the cars SOC meter. Full balance is like 122 volts. So you set the charger to 109 so it stops at that point.
The problem is when you pass that. Granted 122 is absolutely full, the car never reaches that as it only uses x % of the battery. This is why when guys go a maintenance charge it wont register properly til it does a recal.
Plan B is to never fill up the battery or let it do a recal.
Old 09-09-2014, 05:57 PM   #15 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Lol, something about that plan seems just plain wrong, Balto!
Just sneak over to the neighbor's house with an extension cord every night for your grid charger! Problem solved!
