Old 10-02-2008, 08:49 AM   #1 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Anyone else have a maddening bulb removal procedure?
Headlight removal
I know I cn change the high and low beams without going through all of that; however the city lights; now that's another story.
Err I wanted to get the golf inspected today; I guess it will have to wait untill next week.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 10-02-2008, 02:34 PM   #2 (permalink)
I bet doing it with your feet would be maddening!
Old 10-02-2008, 06:39 PM   #3 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 Honda CiViC HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Dude, are you serious???
I can replace my CiViC headlight bulbs (both sides) in 2-3 minutes - no kidding!
Heh!
That would be a deal breaker for me!!!
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Old 10-02-2008, 08:06 PM   #4 (permalink)
EV OR DIESEL
I am serious.
I can change the low beam bulbs in about 5 minutes per side (there is a cover with 2 screws+ a dust cap to remove); this is the city (running) light located in the high beam reflector. Same procedure applies for high beam.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 10-02-2008, 08:38 PM   #5 (permalink)
Red
Red's Avatar
That's insane for a blub replacement. Even my dads 740 isn't that annoying.
Old 10-02-2008, 10:51 PM   #6 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
On a taurus you are supposed to take the entire front bumper off to change the turn signal bulbs!!!!
Luckily, it is possible to mangle your hand past the radiator mount and twist the bulb harness out of the socket.
Old 10-02-2008, 11:58 PM   #7 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Do you have a Bentley manual?
I changed these exact same light (driver's side) on a friend's golf a few months ago - and was quite simple, I thought.
There's a vanity cover with a little light bulb molded into the plastic - held by two screws. Remove two screws and pull off the cover - that's how I got to the holder... Removing the battery and tray could be helpful if your hands are big or like/need a little more space....
Unless you have to remove the headlamp assembly for another reason, I didn't see any reason to go through all that o.0
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 10-03-2008, 01:23 AM   #8 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Geez! I just have to reach in and twist. Done.
At least it isn't a Ford/Merc Contour/Mystique 4-cyl where you have to pull the RF wheel to change the oil filter or the similar Sebring Battery Debacle.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
