Old 09-07-2014, 10:58 PM   #1 (permalink)
3n3rgystar's Avatar
Silver Bullet - '92 Nissan Sentra XE
90 day: 37.59 mpg (US)
1992 Nissan Sentra 4 door auto Inspired by sister and
Sister has a B14 5-speed that she is regularly getting 40-50mpg without any mods. With a hip injury and wife that refused to drive my 5 speed I decided to get another car. Goal was to get a car that would get as good as average as the 5-speed car I was currently driving and had a low cost so I could experiment and mod without worry about hurting the value.
Was also inspired by this thread by blownb310
http://ecomodder.com/forum/showthrea...ods-19024.html
Car as I bought it
Mild mods
Wild mods
Car is a daily driver so some things are a compromise.
Old 09-07-2014, 11:36 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Welcome! Always nice to have inspiration!
Have u raised the psi to 40+?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-07-2014, 11:40 PM   #3 (permalink)
3n3rgystar's Avatar
Thanks!
Current Mods: LED light bulb conversion
Power Side mirror deleted completely moved inside
Radio antenna delete
Shave badges, rain gutters partially done
Windshield wiper deleted easily when needed
Smooth wheel covers
Lightened and Aero headlights
Custom Aero bumper cover
Lexan headlight covers
Grill block
Tire spats
Belly pan underbody tray almost completed
Rear wheel skirts
Front wheel skirts
Sealed panel gaps partially done
Partial kammback
Frontal area reduction
Decrease hood windshield angle
Front air dam
Rear corner airflow curve
Ride height reduction
Lowest viscosity oil 0w-20w
advanced ignition timing
Hot/warm air intake
Synthetic oil
A/C delete
Synthetic transaxle/wheel grease
Synthetic transmission fluid
Thinnest transmission fluid
Increased tire pressure to 60 psi
Light and Low rolling resistance tires 12 lbs
Skinniest tires
Lightweight wheels 22 lbs wheel/tire combo
Weight reduction
General maintenance
Last edited by 3n3rgystar; 09-08-2014 at 01:37 PM.. Reason: forgot to say thanks. Being a lurker am out of practice.
Old 09-08-2014, 01:37 PM   #4 (permalink)
3n3rgystar's Avatar
22 miles commute hilly and somewhat curvy
1.5 miles country 45mph-55mph hilly
.5 miles city 0-35mph traffic light
7 miles country 45mph-60mph hilly
.5 miles country 45-50mph curvy
.5 miles city 0-35mph hilly school zone
.5 miles country 45mph-50mph rough & bumpy
5 miles city 0-45mph hilly traffic lights
6 miles country 35mph-50mph curvy & hilly
Old 09-08-2014, 01:55 PM   #5 (permalink)
3n3rgystar's Avatar
I've got another whole sheet of corrugated plastic not sure which area I am going to address next. Once I figure out what works best did have someone offer to help do it in sheet metal but I dunno I kinda like the light weight plastic. The scales I usually weigh on are broken so not sure how much weight I have taken off yet. I wanted to be more conservative on the interior so not going to be totally stripped like the man van. Still is a 5 passenger vehicle with a functioning trunk. Luckily I was able to find a B13 weight reduction thread on another site(racing purposes) Figure I am somewhere in the neighborhood of 250-300 lbs removed.
Old 09-10-2014, 12:21 PM   #6 (permalink)
3n3rgystar's Avatar
Replaced original wheel tire combo 34 lbs each with 22 lbs each wheel tire combo. Spent all day in the junk yard weighing tires and wheels until I found the lightest ones that I could find which are 13" size also like the originals. None of the 14" or 15" wheels came close to the lightness of the 13" alloys.
48 lbs of unsprung and rotational weight
20 gram lug nuts
1.5 lbs of unsprung and rotational weight saved for the set
Hosed off at least a few pounds of crud when I took the car apart
Changed out Heavy speakers to lighter ones
9 lbs difference and they sound better too.
Removed ashtray, 3 way cable, dual prong, metal brackets cd holder and collection of CDs
5lbs
Removed air conditioning and accessories to a/c system
48 lbs
Removed mirrors they where surprisingly heavy, brackets, fascia, switch, and wiring harnesses for the electric mirror controls
10 lbs
Removed washer reservoir, hoses, sprayers and pump
2 lbs
Removed spare tire, carpeting, factory tool kit and spare tire cover
30 lbs
Removed engine bay brackets, tow hooks, headlight brackets and replaced all with nylon wire ties saving 16 lbs
14 lbs
Removed rear tow hooks, brackets and bolts
5 lbs
Removed front, rear bumpers, brackets, etc
100 lbs
Removed hood,hook latch, misc hardware fenders, and replaced with corrugated plastic.
74 lbs
Using smaller battery saving
12 lbs
Removed metal battery tray and brackets then relocated battery holding down with heavy duty zip ties instead of original metal battery bracket
7 lbs
Relocated coolant reservoir for better weight distribution was originally far forward in the engine bay.
I also have a 1.63 lbs lighter axle to put in once I get some time.
So around 365 lbs and about 50 of that Unsprung and rotational weight.
Old 09-10-2014, 01:13 PM   #7 (permalink)
mcrews's Avatar
never understand removing the a/c.........
are you going to upsize the tires to get lower rpm at cruise? (equals higher mpg)
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-10-2014, 01:17 PM   #8 (permalink)
3n3rgystar's Avatar
Slightly from 70 to 80 but that it not going to go any higher than that. Plus I was reading another user of this type of car was getting better mpg in slightly higher RPM range. Most of the time I am cruising at just above torque converter lockup anyways.
Old 09-12-2014, 03:05 PM   #9 (permalink)
3n3rgystar's Avatar
Installed a new O2 sensor after all the cleaning I did to the fuel system. Hoping this new one (claims to help MPG) actually gets me over the 49 mpg average hump this week.
That and I put a pointed nose on the front and added more pieces of corrugated plastic to the back. Still a work in progress, have an idea for the back that won't interfere with the trunk but I will have to pick up some more corrugated plastic sheets to start working on that maybe this weekend or the next.
Also have an axle I need to change out but I gotta goto a birthday party Saturday so might not have time to do anything else.
Old 09-12-2014, 09:54 PM   #10 (permalink)
3n3rgystar's Avatar
Right now I am tired of all the attention the aero mods are getting so I am thinking of reversing them and only doing stealthy mods that get less attention from the public.
