Old 04-21-2013, 05:45 AM   #151 (permalink)
The PRC.
Some still use belts, some use steel belts which are much stronger than they used to be.
The CVT used in this version of the Nissan Micra
used a kind of magnetic powder clutch instead of a Torque Converter.
Old 04-21-2013, 07:54 AM   #152 (permalink)
Originally Posted by Miller88 View Post
CVTs still have torque converters right? I remember people were complaining that the Ford Five Hundred CVT didn't have a lock up torque converter.
Many CVTs still have a dry clutch instead of a torque converter. Well, altough I like the greater dependability of a torque converter, I should recognise a dry clutch still generates less parasitic losses.
Old 04-22-2013, 03:12 AM   #153 (permalink)
I think the clutch is just used until the vehicle gets going a few MPH then it is a direct connection. There is no torque converter that is used when driving even if you floor it. Otherwise CVTs wouldn't be much more efficient than slush boxes.
Old 04-22-2013, 03:15 AM   #154 (permalink)
Torque converters are also more expensive to manufacture. So, a centrifugal clutch makes more sense.
Old 04-22-2013, 04:18 AM   #155 (permalink)
Torque converters nowadays have very low lock-up points. Since the electronics can tell whether you're in first or fifth, they can either let the torque converter free-wheel up to its lock-up speed or lock it at a very low rpm (around 1,5000 rpm in cars I've driven with the electronic lock-up and manu-matic mode).
The nice thing about a TC over a dual-clutch or a dry-clutch CVT is that the transmission fluid itself bears the brunt of the shock-loads when shifting. And you're throwing that out, anyway, every xx,xxx miles. A dual-clutch system with the dry clutch will eventually need clutch pack replacement, no matter how gently you drive it.
Old 04-25-2013, 06:18 AM   #156 (permalink)
Remove the transmission (or the engine) to replace a clutch pack is the major downside.
Old 04-25-2013, 07:18 AM   #157 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
What is the life of a computer controlled dual clutch? 200,000? Much longer and with less loss than a CVT belt.
Old 04-25-2013, 12:03 PM   #158 (permalink)
If you've got a defective one... immediately. Many people have no problems, some have to replace them a couple of times within the warranty period.
Same with a regular manual. A little more complex, but not hugely so.
Old 04-26-2013, 09:26 AM   #159 (permalink)
No wonder they've been increasing popularity.
Old 04-26-2013, 10:42 AM   #160 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Did Nissan change their CVT design? I drove a 2011 Versa a while back and it felt like it was an Automatic transmission that was on it's last legs. Revs would randomly spike to 4000RPM going 55MPH and it felt like a dieining automatic transmission taking off from a stoplight.
I drove a 2013 Sentra and it seems to not be as rubber-bandy feeling. It also feels like the engine is connected to the wheels in a lot more substantial way than the Versa. It acts a lot like a manual with a clutch up taking off, then the revs just stay the same. Doesn't seem to be as rubber band-y feeling as the 2011
