Old 07-24-2009, 02:37 AM   #1 (permalink)
Anyone tried HHO on a diesel?
Looking to buy a diesel car and add some type of hho producer to increase milage. Talk to me.
Old 07-24-2009, 02:55 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Search and ye shall find. The only benefit it could provide in a diesel engine is serving to do the same job with less fuel. It would require tuning before it could actually save you fuel though, since the injection system doesn't know what's actually going through the intake, and won't compensate for it by chaning fuel curves. (Assuming you have a non-ECM diesel.)
Old 07-24-2009, 03:30 AM   #3 (permalink)
Find me an HHO system that works at all- on anything- first.
Mustang Dave (07-28-2015)
Old 07-24-2009, 09:24 AM   #4 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
Come on - lets be nice they work PERFECTLY..
they reduce the weight in you wallet - that inturn increases MPG.
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 07-24-2009, 01:43 PM   #5 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
I would be fine with an HHO system.... if it meant bringing a bottle of hydrogen into the car and metering it into the intake. However, if you are generating it on-board, well, TANSTAAFL is true in thermodynamics, too.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 07-24-2009, 02:41 PM   #6 (permalink)
I always have to fight the urge to refer to HHO as HO HO HO.
Old 07-25-2009, 01:16 PM   #7 (permalink)
This guy seems like the most legit I have seen so far...he even talks about all the troubles he had with the system.
edit: myself, I'd go with propane....
“The Fuel Stretcher” is a device that allows the use of supplemental propane or compressed natural gas on turbodiesel engines. When propane or cng is injected into the air intake of a turbodiesel, it reduces the amount of diesel fuel necessary to produce the needed power. It is basically substituting propane or cng for some of the diesel fuel. This is also called fumigation. The engine must always use some diesel fuel, because the diesel fuel ignites the gas. The Fuel Stretcher allows the user to adjust the amount of gas consumed from very little to approximately two to three gallons of gas to every gallon of diesel fuel. This can amount to a substantial reduction of the operating cost per mile. The gas also increases the power output of the engine. Another side benefit is much lower emissions and less lubricating oil contamination.
The Fuel Stretcher comes as a complete kit with easy to follow instructions for installation. The only additional item you need is a propane or cng tank.
Theory of Operation
No gas is used when the engine is idling. A hose is connected from the regulator to the air intake between the air cleaner and the turbo. When the engine load increases, the turbo creates an increasing vacuum in the air pipe. This vacuum activates the propane regulator to begin supplying fuel. As the engine load continues to increase, the vacuum continues to increase, causing the regulator to supply more and more gas. A flow control valve in the fuel vapor line controls the overall fuel curve. A dash mounted switch turns the unit on and off, and it also turns on and off with the ignition switch. The unit draws liquid propane from the tank to eliminate pressure loss due to evaporation within the tank. Consequently, the unit is water heated and is connected in series with the heater core. The kit includes all necessary hoses and hardware to make this connection.
Operation on a GM Duramax has given as much as 60 miles per gallon of diesel fuel. At this consumption rate, the propane consumption was approximately 20 miles per gallon. Another great benefit is that it will add up to 100 rear wheel horsepower.
CNG, (compressed natural gas) is now available to supplement diesel fuel for turbodiesels. Comparable results to propane have been achieved. For more information, go to this page.
If you would like more information, please call DeLuca Fuel Products at 740-622-7942, or email us at marc@delucafuelproducts.com.
60mpg diesel and 20mpg is a 40mpg average folks.
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, 8mpg (sorry).
1960 Nash DIY Hybrid Project
Old 07-25-2009, 04:03 PM   #8 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Uhhhhhhh.... Are you sure it works like that? *hinthint*
Old 07-26-2009, 11:04 AM   #9 (permalink)
The Odyssey Van - '11 Honda Odyssey EX-L
90 day: 29.1 mpg (US)
silver racecar - '13 hyundai accent GS
90 day: 38.8 mpg (US)
It would work like that if you use equal parts of both but this is probly not the case. Example if you use equal parts the mpg avg would be 40mpg but if you use 75% at 20mpg and 25% at 60mpg the avg would drop to 30mpg due to the amount used being weighted more towards the one that yields lower mileage. But hey, 30mpg is not bad in a big truck!
Old 07-26-2009, 01:26 PM   #10 (permalink)
Dammit, don't try to pull a Doug Palmear!
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 122 05-24-2014 09:05 PM
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
Diesel Power Magazine Fuel Economy Shootout JQmile EcoModding Central 3 03-18-2009 09:23 PM
Poll for Americans: What about Diesel engines? hal9999 General Efficiency Discussion 117 01-07-2009 07:23 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
