Old 09-13-2008, 02:22 AM   #1 (permalink)
Skeeter - '95 Geo Metro
90 day: 44.78 mpg (US)
ALDL . . . What am I supposed to do with this?
I recently purchased a 1995 Geo Metro 3 cyl. To my dismay there is no obdII connection in the 95 Geo. So I do a little research and find that I have a ALDL. Does anyone know if its possible to rig up a mpg instrument to the ALDL connection? I'm afraid that the answer is no, but Im new to hypermiling so any information would be great!
Old 09-13-2008, 10:31 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'm not sure what ALDL is, but you could probably hook up an MPGuino.
Welcome to ecomodder.
Old 09-14-2008, 05:20 PM   #3 (permalink)
'El Misil' - '91 Opel Calibra 2.0i
Last 3: 29.02 mpg (US)
ALDL = Assembly Line Diagnostic Link , a proprietary on-board diagnostics system used by General Motors before OBD-II was standardized in 1996, mostly 12-pin plug, with some 10-pin and 5-pin variants.
From what I've read I think Scangauge only works with 16-pin OBD-II cars.
However in principle ALDL provides all that is needed for fuel consumption calculation. There is some free software that can display engine rpm and injector pulse width, have a look here:
ALDL OBD1 OBD cable OBDI OBD2 engine codes
Old 09-14-2008, 07:37 PM   #4 (permalink)
Red Beast - '82 Honda V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 Honda CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Dodge Neon SXT
90 day: 28.71 mpg (US)
Looking at the protocol that I could find, you can get speed and fuel flow rate. It shouldn't be trouble for you to write your own 'duino software. It might be easier to merely use the MPGuino software (community supported) and let someone else do the hard work.
