Old 06-28-2008, 03:57 PM   #1 (permalink)
99CivicEX - '99 Honda Civic EX
Material for LGB
What is a good material to make a lower grill block out of? I want to make it hardly noticeable\factory look? Something that can be found locally cheap as well...
Old 06-28-2008, 06:25 PM   #2 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
coroplast
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 06-28-2008, 08:15 PM   #3 (permalink)
Where can this be found?
Old 06-29-2008, 12:35 AM   #4 (permalink)
A sign maker is a good choice. Even better is a sign maker supplier, but a local sign shop will do just fine. A custom order of black coroplast cost me all of $1/square foot.
Expanding, sprayable foam as an aero construction / shaping material MetroMPG Aerodynamics 10 01-18-2013 03:04 AM
Eye candy...drool material Stan Aerodynamics 7 07-12-2008 03:03 PM
air dam material saunders1313 DIY / How-to 22 07-08-2008 04:50 PM
New material from dupont might cut auto weight significantly SVOboy General Efficiency Discussion 4 02-28-2008 11:23 PM
