Old 08-16-2010, 08:23 AM   #1 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
1.8L Prius ICE 'idle' fuel consumption
Hi,
When a Prius is over the hybrid threshold, 42 mph for 1.5L and 46 mph for the 1.8L, the control laws require the engine continue to run. By shifting into "N", all power to and from the two motor generators is removed and the engine controller will continue to run the ICE with no load . . . it is at the closest the engine can be to idle:
Time_stamp MPHRPMMAF (gm/s)
02:18:02.381 69 1130 2.28
02:18:03.865 70 1152 2.28
02:18:05.334 70 1152 2.29
02:18:06.802 70 1152 2.48
02:18:08.271 71 1152 2.20
02:18:09.771 72 1152 2.50
02:18:11.240 73 1184 2.64
02:18:12.709 73 1179 2.29
02:18:14.177 74 1191 2.17
02:18:15.646 75 1184 2.29
02:18:17.115 75 1184 2.59
02:18:18.599 76 1184 2.68
02:18:20.068 77 1184 2.62
02:18:21.552 78 1184 2.14
average_value 73 1169 2.39
So using this set of data, we can calculate:
2.39 gm/sec air
(14.7 stoich ratio)
0.1625 gm/sec fuel
(3,600 sec/hr)
585 gm/hr fuel
(2,659 gm/gal)
0.22 gal/hr
(73 miles/hr)
331.7 miles/gal
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following User Says Thank You to bwilson4web For This Useful Post:
redpoint5 (08-31-2013)
Old 08-16-2010, 01:47 PM   #2 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Dude if you think you're gonna fare better in a head-on with a full-frame econoline you're just kidding yourself. For one thing theres not much sheet metal in front of you. Another thing is you have a thick steel frame. Whats that gonna do? Well it will transfer the impact to the other vehicle of course, and also, to you. Its well proven that a vehicle that folds up like a pop can is better. I would much rather have the body of my car absorb an impact than my spinal column.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 08-16-2010, 03:35 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I wonder how it compares to the previous gen's 1.6L.
It's easy to make an Insight idle, in which case it burns 0.11gph. I should repeat that trial with the headlights on and see if it's 0.13gph like I predict. Hmm, could it really be 0.09gph with zero 12V load instead of the 200W base load?
Originally Posted by bwilson4web View Post
(Sorry, I don't understand Ecomodder tables.)
That's fine, I understand text tables quite clearly. If you want a monospaced font, that's [ code ] [ /code ]
If you must have a table, I recommend Free BBCode Table Generator Tool
Old 08-16-2010, 05:36 PM   #4 (permalink)
Engineering first
Originally Posted by RobertSmalls View Post
I wonder how it compares to the previous gen's 1.6L. . .
I'll go back and try it again. I get so frustrated when a tools defaults to "wipe out your previous data" without a prompt.
Thanks for the table tip . . . I'm not sure it is any better due to the larger number of gratis line feeds.
Bob Wilson
Pre-heating the Prius Transaxle and Engine for better fuel economy orange4boy Hybrids 70 10-07-2015 11:07 AM
Canada's top fuel efficient cars (by class) for 2010 MetroMPG General Efficiency Discussion 3 05-09-2011 01:56 AM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
EOC <> zero fuel consumption Bearleener EcoModding Central 2 11-26-2009 08:26 AM
Illustrated: fuel consumption at higher speeds MetroMPG Hypermiling / EcoDriver's Ed 1 11-28-2007 06:58 PM
