Old 12-07-2009, 10:23 AM   #1 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
Very frustrated (winter MPG)
I've had my Jeep out offroading a bunch, which in itself isn't bad. Its nice to get away from people.
My frustration is that now its winter, I expected an MPG drop. What I DIDN'T expect was the almost 4MPG drop. And I haven't significantly altered my driving habits, other than slowing down a bit when its slick. I understand the fuel formulations change and that warmer air is better. And I didn't add that much weight with my extra winter carry stuff.
During one offroad trip I did have the vacuum line come off the MAP sensor, but when my CEL came on I did the key cycle check for codes, and it showed the MAP, sure enough replaced the line with a new longer (2" longer to allow for movement) hose.
MAYBE, I need to reset the computer. I am going to do an upper grill block fro the winter and see what I can get away with (Jeeps overheat WAYYYY too easy)...
When it comes to Heroes, RENEGADES are mine!
Old 12-07-2009, 10:42 AM   #2 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Jeep Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Kia Sedona LX
WAI for Jeeps
I dont know how your airbox is set up compared to that of a Cherokee (XJ), but FastPlastic had an interesting and innexpensive way to get warmer air to the intake.
http://ecomodder.com/forum/showthrea...tml#post143271
Hope this helps!
Old 12-07-2009, 11:23 AM   #3 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Winter blend of gass, and cold air are bad on gas mileage.
Old 12-07-2009, 12:17 PM   #4 (permalink)
Cold weather hurts FE many ways:
Greater air drag because of denser air (I remember 6% increase for 60F down to 30F)
Longer warm up time, so the fuel mixture stays richer longer
more resistance in bearings and tires because of low temperature
cold weather gasoline formula
greater electrical use: defrosters, lights, etc. (even A/C in defrost mode)
reduced traction, increased rolling resistance in ice and snow and slush and wet roads
Old 12-07-2009, 05:06 PM   #5 (permalink)
4-mpg
A 3-mpg drop for a full-size passenger car would not be uncommon during winter.
You get an extra whammy from the transfer case and front differential gears wetted with temp-induced higher viscosity lube do to the cold.
I'd like to say that a switch to synthetic gear oil would help,but my own experiences with Red Line full syn and Mobil-1 forbid me to.
There might be a little comfort in knowing that everyone else with a vehicle like your's is in the same boat.
I'm down a half mpg in the T-100 so far.I'll lose another 1.5 mpg before winter's over.
Old 12-07-2009, 06:08 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
zjrog -
I was happilly humming along with 44+ MPG in the summer, and now I am being baraged by lots of barely 40+ tanks. I thought it was going to get better, but now here comes a week of rain.
I feel your MPainG.
CarloSW2
American Solar Energy Society
Old 12-07-2009, 06:09 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
If you look at my fuel logs, you'll see about a 30-40% drop in FE during the winter. It's a big sucker. Just gotta wait it out (or migrate south I guess).
Old 12-07-2009, 06:22 PM   #8 (permalink)
discovery's Avatar
Yes migrate to the south , no change in temperature down here. It is almost always 80+. Last winter, sorry I ment to say JAN, FEB, MAR i had to use my A/C several times, but this is the trick when the summer comes it's like HELL...
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 12-07-2009, 09:15 PM   #9 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
I loose 5+ in the winter, and I am paying over ~5.30 a gallon, quitcher wining. I can't even blame mine on summer/winter gas as the tanks out here get filled over the summer and drained over the winter (our fuel is barged in) so it is a stable over time blend.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-07-2009, 11:33 PM   #10 (permalink)
Ecomod noob
zjrog's Avatar
You guys know how to make a guy feel better... I use synthetics already, but don't recall a drop this severe last winter. I'll look into that airbox mod.
Moving south is not an option at this point (I really like Utah and snow). And bestclimb, Alaska is the only state I haven't been to yet... But when I do, it will be summertime!
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 10:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
MPG Decline from Colder Weather or Winter Blend Gas or ??? cfg83 EcoModding Central 11 11-24-2009 11:55 PM
High MPG Winter Car - AWD? - $4K or less pint EcoModding Central 12 09-24-2009 09:55 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
