EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Attatchment of Grill block ideas (https://ecomodder.com/forum/showthread.php/attatchment-grill-block-ideas-19175.html)
Blu3Z3rg 10-17-2011 12:02 AM
I have cut out a form for the front grill block.
I want to have it removable without drilling anything visible.
I'd like to have it removable fairly easily, as anytime I tow, I get warm, and would rather have it off as a precaution.
Zip tie it every time and just buy a ton of em?
Any type of fastener that will go through the grill and be able to come off by hand?
Thanks in advance for the ideas!
tercelguy 10-17-2011 12:50 AM
Reusable zip ties?
Arragonis 10-17-2011 04:54 AM
Zip-ties are cheap.
Ecomodder member Vekke has invented a new type of zip-tie which looks interesting.
Another type is the bolt that came with my Fabia grill block - it was a bent piece of metal with a screw hole and a screw, the metal hooked behind a grill slat and the end was turned 90 Deg with a hole for a bolt to go through.
http://ecomodder.com/forum/member-ar...195-grill2.jpg
or
http://ecomodder.com/forum/member-ar...3194-grill.jpg
Or you could use the method shown here which is removable with a screwdriver as long as you can get behind the grill. The parts are available in most DIY shops.
http://img520.imageshack.us/img520/7...2mediumcb3.jpg
Daox 10-17-2011 12:25 PM
I've used a few methods on mine. Zip ties on one. Another one used thumb screws and fender washers. My favorite so far used wood blocks to screw to. It gives a really secure mounting pad to attach whatever you want.
beatr911 10-17-2011 12:48 PM
They make velcro "zip ties" as well for containing computer cords which may work in some cases.
Still looking for a better idea myself as access behind the block-off is really restricted to getting my hand back there. I also want a really clean and smooth final installation look without zip ties right in the middle of an otherwise clean surface.
Vekke 10-18-2011 12:42 PM
The ziptie plugs are exellent for that purpose also. Today I blocked the second grill hole on my customers diesel Smart. No holes needed and the assembly and diassembly is easy. Costs of the plugs are 2€ per piece. That includes one 300mm long ziptie and one ziptie plug. At the moment I mill those plugs from aluminium by hand so it takes time.
So 20 ziptie plugs will cost shipped on letter to states 40€ which is 55 US$. Smaller than 20 piece orders there will be 2€ shipping cost.
I will try to make a grill block assembly video with ziptie plugs tomorrow.
COcyclist 10-18-2011 01:19 PM
I like the idea of the ziptie plugs. I could have used at on the lower left grill on the VW. I used black foam pipe insulation between the horizontal bars on my upper grill. It is cheap, quick and easily removed
Sven7 10-19-2011 04:24 AM
Maybe a carriage bolt or a bolt with a washer on the front and a wing nut on the back. You could paint the bolt head/washer black to match the grille block and the nut will be out of view. That is, assuming you can reach the rear of the grille.
Velcro sounds like a good idea. You could put velcro straps around the grille slats and have a piece of velcro on the block. Easy peasy.
Otherwise, maybe magnets of some kind? I don't imagine the block will want to slide around a ton anyway, but some decent magnets might hold it reasonably well.
Vekke 01-30-2012 02:13 AM
At the moment I am using regular zipties in the grill block, because there is no tool for the plugs :/.
http://www.youtube.com/watch?v=J8Gjk...ature=youtu.be
Here is a video how to do it.
Arragonis 01-30-2012 04:39 AM
Originally Posted by Sven7 (Post 266215)
...Otherwise, maybe magnets of some kind? I don't imagine the block will want to slide around a ton anyway, but some decent magnets might hold it reasonably well.
I tried some of those super strength magnets for a possible tail extension / kamm back in the style of the black Firefly featured around here a while ago - my car only has a glass tailgate.
They were heavy but didn't hold enough.
