Old 12-01-2010, 09:42 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
New grill block mounting method
Last year, my grill block on the Prius worked pretty good. However, on a windy day towards spring I did have one of the thumb screws back off and I ended up loosing it and kinking the coroplast. So, I thought up a new way to mount the grill block that I think makes a lot of sense and is incredibly easy to do.
I started out with some left over 1x4s I had laying around. These scraps worked perfectly for the project. I drilled a clearance hole for a 2.5" wood screw in two of the blocks and a pilot hole in the other two.
I then drilled a countersink in the blocks with the clearance hole so the stainless deck screw I was going to use would sit below flush.
Next, I stuck the block with the pilot hole behind the grill and screwed them together with the block with the clearance hole on the outside of the grill.
And then I mounted the other. Now, the blocks provide us a place to screw the grill block to. It also positions the grill block much more flush with the bumper instead of being inset like most grills are. This should improve aero a little bit. Also, its very easy to compensate for different grill depths by using different thickness outer blocks.
Lastly, I held my grill block up to the blocks, drilled holes, and used button head screws and fender washers to hold it on. It is much more sturdy than my last method of attaching the grill block and it sits almost as flush. A little tweaking will fix that though.
The Following 2 Users Say Thank You to Daox For This Useful Post:
alohaspirit (12-01-2010), MorphDaCivic (12-02-2010)
Old 12-01-2010, 10:01 PM   #2 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
i like the idea
is that black coroplast?
Past Present Future?
Old 12-01-2010, 10:37 PM   #3 (permalink)
Aveo - '08 Aveo LS
You blocked lower and kept upper open?
Old 12-02-2010, 06:41 AM   #4 (permalink)
CM400E - '81 CM400E
Originally Posted by alohaspirit View Post
i like the idea
Yup, its really dusty, but it is black coroplast.
I have yet to block the upper grill. It'll be done eventually.
Old 12-02-2010, 10:37 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
That's just to keep the snow out
Piwoslaw's Peugeot 307sw modding thread
Old 12-02-2010, 03:25 PM   #6 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...I found some "heavy-duty" Velcro™ squares that seem to be holding up well (so far) at holding things in-place behind the grill...in the space between the bumper-fascia and the radiator.
Old 12-03-2010, 08:21 AM   #7 (permalink)
CM400E - '81 CM400E
I haven't been able to drive the car since doing this. But, the wife reports back that the car is warming up and maintaining temperature much better now. Heat can be a real problem for her in the winter since she transports plants and they need to be warm.
The Following User Says Thank You to Daox For This Useful Post:
wyatt (12-03-2010)
Old 12-03-2010, 11:47 AM   #8 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Nice. I am going to have to install something again this year on our Prius. Last year it was clear acrylic and it worked well. I would use it again, but the acrylic was so thin that rocks punched holes right through it. If it didn't get thrown out, I could use it as a template for this years... I had used black electrical tape around the perimeter to prevent cracking/breakage along the edges and black zip ties to attach. it was kind of a pain to get done, but really didn't take that long. We had good heat even driving back to Alabama from Wisconsin in -6degF weather at night! Since we had nothing to compare against, I didn't know if it made a difference, so thanks for that tidbit!
Old 12-03-2010, 12:36 PM   #9 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
Looks like a nice set up. If I had to make one for my car I think I would use the same setup.
thread added to the wiki section on grill blocks.
Old 12-03-2010, 09:04 PM   #10 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Nice job! Mine is McGyver'ed: Lengths of pipe insulation built up into chunks with duct tape, jammed into the grill slots. Not nearly as nice as yours.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
