Old 10-17-2011, 01:02 AM   #1 (permalink)
2005 Dakota - '05 Dodge Dakota SLT
90 day: 15.26 mpg (US)
Attatchment of Grill block ideas
I have cut out a form for the front grill block.
I want to have it removable without drilling anything visible.
I'd like to have it removable fairly easily, as anytime I tow, I get warm, and would rather have it off as a precaution.
Zip tie it every time and just buy a ton of em?
Any type of fastener that will go through the grill and be able to come off by hand?
Thanks in advance for the ideas!
Old 10-17-2011, 01:50 AM   #2 (permalink)
Tercel summer 2011 - '99 Toyota Tercel CE
90 day: 40.31 mpg (US)
gas guzzler - '04 Honda CR-V 4WD
90 day: 25.65 mpg (US)
Tercel fall 2011 - '99 Toyota Tercel CE
90 day: 34.58 mpg (US)
Tercel Overall - '99 Toyota Tercel CE
90 day: 40.24 mpg (US)
Reusable zip ties?
Sorry, new users are not permitted to post links in their signatures.
Old 10-17-2011, 05:54 AM   #3 (permalink)
The PRC.
Zip-ties are cheap.
Ecomodder member Vekke has invented a new type of zip-tie which looks interesting.
Another type is the bolt that came with my Fabia grill block - it was a bent piece of metal with a screw hole and a screw, the metal hooked behind a grill slat and the end was turned 90 Deg with a hole for a bolt to go through.
or
Or you could use the method shown here which is removable with a screwdriver as long as you can get behind the grill. The parts are available in most DIY shops.
Old 10-17-2011, 01:25 PM   #4 (permalink)
I've used a few methods on mine. Zip ties on one. Another one used thumb screws and fender washers. My favorite so far used wood blocks to screw to. It gives a really secure mounting pad to attach whatever you want.
Old 10-17-2011, 01:48 PM   #5 (permalink)
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
They make velcro "zip ties" as well for containing computer cords which may work in some cases.
Still looking for a better idea myself as access behind the block-off is really restricted to getting my hand back there. I also want a really clean and smooth final installation look without zip ties right in the middle of an otherwise clean surface.
Good design is simple. Getting there isn't.
Old 10-18-2011, 01:42 PM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
The ziptie plugs are exellent for that purpose also. Today I blocked the second grill hole on my customers diesel Smart. No holes needed and the assembly and diassembly is easy. Costs of the plugs are 2€ per piece. That includes one 300mm long ziptie and one ziptie plug. At the moment I mill those plugs from aluminium by hand so it takes time.
So 20 ziptie plugs will cost shipped on letter to states 40€ which is 55 US$. Smaller than 20 piece orders there will be 2€ shipping cost.
I will try to make a grill block assembly video with ziptie plugs tomorrow.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 10-18-2011, 02:19 PM   #7 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I like the idea of the ziptie plugs. I could have used at on the lower left grill on the VW. I used black foam pipe insulation between the horizontal bars on my upper grill. It is cheap, quick and easily removed
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 10-19-2011, 05:24 AM   #8 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Maybe a carriage bolt or a bolt with a washer on the front and a wing nut on the back. You could paint the bolt head/washer black to match the grille block and the nut will be out of view. That is, assuming you can reach the rear of the grille.
Velcro sounds like a good idea. You could put velcro straps around the grille slats and have a piece of velcro on the block. Easy peasy.
Otherwise, maybe magnets of some kind? I don't imagine the block will want to slide around a ton anyway, but some decent magnets might hold it reasonably well.
Old 01-30-2012, 03:13 AM   #9 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
At the moment I am using regular zipties in the grill block, because there is no tool for the plugs :/.
Here is a video how to do it.
Old 01-30-2012, 05:39 AM   #10 (permalink)
The PRC.
Originally Posted by Sven7 View Post
...Otherwise, maybe magnets of some kind? I don't imagine the block will want to slide around a ton anyway, but some decent magnets might hold it reasonably well.
I tried some of those super strength magnets for a possible tail extension / kamm back in the style of the black Firefly featured around here a while ago - my car only has a glass tailgate.
They were heavy but didn't hold enough.
