Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-20-2008, 07:38 AM   #1 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
Attic insulation
I had recently asked about using attic insulation to wrap a water heating in to keep it warmer. I know adding insulation to the attic will help lower energy costs (I did and it saved me ~$150 the first year), but is there a point at which the amount of insulation is really not adding any more R values? I had R-13 in the attic when I bought the house (very low for NJ), then I put in R-19 over that. As stated in the post about the water heater, sometimes I can get insulation at an auction, a batt or two at a time, and sometimes a little older, but is it worth adding more if I can get it cheap enough? I'm sure there is a point when adding more is just not going to help and I'm wondering what is that point?
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 09-26-2008, 10:40 AM   #2 (permalink)
the Mule - '99 Dodge Dakota
90 day: 14.54 mpg (US)
The standard recommendation for attic spaces is R-50. More is usually better but personally I wouldn't layer it more than two or three layers because it's a fairly good idea to inspect it every now and then for water leeks and "critters" and too much would finding a wet spot difficult, not to mention being able to safely walk the rafters when you need too.
"Without deviation from the norm, progress is not possible"---F. Zappa
If we can't be free, at least we can be cheap"--- Again F. Zappa
My guilty little pleasure
Old 11-28-2008, 10:33 AM   #3 (permalink)
Mad Scientist
Silver Civic - '97 Honda Civic 2 door DX coupe
90 day: 35.57 mpg (US)
Wagon - '01 Ford Foccs ZTX
90 day: 35.46 mpg (US)
Check out this thread, It covers a lot of stuff
Larryrose11
http://ecomodder.com/forum/showthrea...tion-3870.html
Attic insulation Daox Saving@Home 39 12-13-2012 09:24 PM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
Insulation for water heater saunders1313 Saving@Home 8 09-15-2008 07:57 PM
Efficient attic ventilation Daox Saving@Home 8 07-18-2008 09:31 AM
How-to coat insulation foam to make it stronger? NoCO2 DIY / How-to 18 06-17-2008 09:47 PM
