Old 01-18-2015, 05:13 PM   #1 (permalink)
83gs1100g's Avatar
92 vx egr not engaging?
I have a vacuum gage on the vacuum line to the egr so I know when it turns on and it never does? I got a new cvc so I know thats good. I tested the egr solenoid and checks good. I swapped ecu no help. I ohm the orange/blue strip wire from egr solenoid to ecu and was good. My question is what sensor or sensors does ecu need to engage the egr? Maybe I have a bad sensor to the ecu so egr can't engage? Any thoughts???
Old 01-18-2015, 09:50 PM   #2 (permalink)
turbothrush's Avatar
2 x wrecked vx - '92 Honda Civic Vx
90 day: 62 mpg (US)
Are you sure your never getting vacuum ? Even for only a second or so when changing gears at high rpm say over 2800 rpm. Vx egr seems to be for emissions only not mpg so you won't see vacuum in cruise
Old 01-18-2015, 10:39 PM   #3 (permalink)
83gs1100g's Avatar
O ya definitely. Zero vacuum. I have a vacuum gauge on it. There needs to be a constant vacuum on egr to keep it open when cruising. The egr solenoid is not engaging. That's what I am trying to figure out what sensors are used to allow ecu to turn it on?
